Brake upgrade
BrainDead
I drug my 6000lbs boat down the 5800ft hill today for the first time and halfway down the brakes started heating up and my foot kept going further to the floor, yes I have trailer brakes and they were working, I'm looking for an upgrade to be on the safe side.
I searched the forum but didn't come up with any results.
I know that Baer and EBC exist and probably have upgrades, but does anyone have firsthand experience with a kit that delivers results?
1BADI5
DMV
Wilwood has a couple options as well.
I do not have Wilwoods in my Tahoe, but I have a set of their 6 pot calipers on my Colorado with their track pads and the brakes are ****** amazing.
There are other more cost effective options though. There are companies that my brakes to retrofit corvette ZO6 or even the ZR1 calipers to the GMT900 trucks. I have a set of brackets to adapt ZO6 calipers and would mate with the Baer 14" rotors.
St. Louis
Powerstop is another brand out there that I've heard of. I have no personal experience with them, just throwing it out there.
exp500
That also sounds like a typical new driver downhill in big trucks. If you ever noticed on a steep/long downhill, big trucks get on the brakes and drop speed 5-15 mph and then stay off to cool the brakes,until the next must apply event. Also your trailer brakes are definately in question here, as my old k2500 has come down many times with 12000# trailer ( which I consider about 3000# more than it should be pulling) with no brake overheating. Still had Looonnnngggg stops. which i figure is what you are mainly referencing. Was still braking shorter than a fully loaded semi. After Upgrading brakes, tires will be the weak point for braking. Hope this helps in your diagnosis/decision. Towing will never stop like a single unit.
St. Louis
What year vehicle?
Starting In 2012 they have powertrain braking when in tow/haul mode, and in 2013/2014 they have it in normal mode.
Powertrain braking lets the transmission downshift to help slow the vehicle on downhill grades and not having to use the brakes as much.
Tozan
Overlander
Beauregard, Louisiana
What year vehicle?
If you have an earlier model just manually down shift to save your brakes. I run in the mountains all the time with no problems. Your over heating and fading will not be improved even with better brakes if you do not down shift.
I do have the EBC rotors and yellow pads they do help in stopping my larger 35 inch tires and I would recommend them if you need additional braking.
B
BrainDead
What year vehicle?
To answer all your questions cars an 07, I had tow/haul on and I was in manual mode and was downshifting. This road doesn't give you much time to let the brakes cool down before you're into the next corner. This car does have power train braking but as stated before was in manual mode so it didn't kick in
I Have had an 01 2500 and an 02 3500 that would stop this load just fine on that hill the way I drive without fading or overheating and yes I know the brakes are bigger but the trucks are also a lot heavier
B
BrainDead
You happen to know the company's name?
petethepug
Michael
SoCal
The current and best upgrade using Brembo 6 piston calipers from the CTS V carbon ceramic set up with standard pads and standard iron discs is here …
https://ctsvbrakeswap.com/products/gm-truck-suv-6-piston-c6-zr1-caliper-big-brake-bracket-kit
20" minimum rims needed. The issue is that the 16" discs that Centric / Stoptech manufactures for GM are on back order due to COVID related shipping and manufacturing delays. I have not looked into purchasing the same disc as an OEM part from GM # 84263238.
The calipers are massive C6 Corvette ZR1 Monoblock units made by Brembo for the 09-13 ZR-1 Vette with carbon discs. I'm waiting on the discs to come in from Stoptech to install the kit. I already shelled out the $9h for new calipers. I went with this kit because of the massive discs. This kit is essentially a clone of the factory BBK for 2015+ vehicles listed for $2.6K here …
https://www.brembo.com/en/company/news/brembo-and-gm-team-up-on-performance-front-brake-kit
The kit allows standard and less expensive ZR1 mono block calipers to be used with an adapter instead of Brembo's proprietary kit made just for the offset of the GM / Chevy / Cadillac trucks.
Baddawg
Vail, Colorado
Good thread, all the upgrades on rotors and calipers are certainly a big help, big change. BUT
break fade is often from old break fluid that has absorbed water.
Have you completely flushed the break fluid in the last two years?
BG1988
use the engine braking that is what it's for
13BurbanKid
Port Charlotte, FL
I have already purchased this kit to put on my truck once I go to the 26's. Believe it or not TireRack had a pair of these rotors in Delaware and I got them. I searched for days trying to find them. Once I get my wheels and drop kit I will be doing the brake upgrade at the same time.
1BADI5
DMV
I bought them from a member on another forum.
But I will be selling them soon since I'm going another route.
New, never mounted with all new hardware...... LMK if you're interested
1BADI5
DMV
For a daily I say some quality rotors, EBC YellowStuff pads, stainless braided lines and DOT3 flush and done.
Everything mentioned above I have on my PPV right now. Best brake set up I've had in a full size SUV outside of a full blown big brake kit
B
BrainDead
I've only owned the car for 8 months, guess that's next on the list
B
BrainDead
I'm interested, if you can find out who made them and if they have any instructions on the web.
It's my daily and don't want it to be down while waiting for parts
Foggy
KS
The stoptech rotors and pad kit for the "towing" .. I think they call it Z-23 or something
would be right on for a daily driver that you don't want to spend a mint on.
Do the front and rear... Flush/bleed your brake system completely so you get
out the old water and contaminants. Then do another bleed in a few weeks !!
I doubt you need a $2500 braking system for a daily with occasional towing
1BADI5
DMV
Sure it was from a member on the SilveradoSS forum that makes them. Let me find the link for you. If you feel good with it, I can ship them to you on Friday.
Definitely a quality part, nice weight, feel and fit/finish.
bfourman
Indiana
X-ray Nerd
