Brake pedal squeal when pressed hard
BigDogYJ
Earth
So I did some searching and didn't see anything that matched. Nearly every truck I own has Hydroboost brakes so the vacuum booster in this 2013 is not part of my wheelhouse per-se. Since we've decided to keep this rig I've been going through it with a more fine tooth comb.
I've noticed a couple times when pressing the brake pedal kinda hard especially during a panic stop I get this high pitch squeal noise like an air leak or something like that. No warning lights or errors whatsoever and the vehicle drives fine, brakes fine, no rpm fluctuations when this happens, etc.
I can reproduce it even when parked and pressing ******* the pedal. The pedal doesn't sink or anything like that. Not sure what it means. If the vacuum booster needs to be replaced due to this then I'd likely just upgrade to hydroboost. Any ideas?
BigDogYJ
BigDogYJ
Earth
I had to re-read my post to figure out what I originally typed here....
apparently im being censored for using the words "hard" and "on" next to each other.
Lets try describing it as "pressing firmly on the pedal."
mikez71
Maybe the check valve if not the diaphragm? idk.
Try pumping it until you're out of vacuum and see if it still makes noise?
Not the pedal bushing squeaking?
BigDogYJ
BigDogYJ
Earth
ok so I played with it a bit tonight and the pedal firms up after the 2nd application while the truck is off. pushing and holding on the pedal while starting causes the pedal to sink id say beyond 50% which is likely normal.
However I was able to confirm that pushing the pedal fully to the floor or as far as it will go does not cause the noise. It appears to only occur with moderate pedal pressure about 50% travel or so and it slowly fades out then it won't repeat until im assuming vacuum builds back up again. when pressing the pedal further it seems to stop. Normal driving I don't ever hear it but if I have to stop sudden or harder than usual (as least for me -- im a pretty mellow driver, generally) then I usually hear it and honestly my wife looks at me funny because the noise occurs if I have to apply brakes harder than I usually do so its pretty apparent. tried to get a video of it here. hopefully this helps.
And yes listening to this video it sounds like the pivot bushing or whatever it is could use replacement too but I think that's separate from the bleed sound im hearing.
BigDogYJ
BigDogYJ
Earth
yeah I can try that next and report back.
Yes I use it for a few nice features and displaying engine/trans data on the DIC when im curious.
Bronson357
I can't exactly tell but is there any chance it's coming through the speaker? Bad ground when you move the pedal?
BigDogYJ
BigDogYJ
Earth
Interesting thought. It does seem to change slightly when I change the pressure on the pedal. And it doesn’t seem to be affected by moving the adjustable pedal position. But worth going under there to take a look. I’ll have some time tomorrow to pull the vaccuum hose and plug it then see if I can reproduce it. I’ll update after.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Did I miss where you said you have adjustable pedals or did you just now share that?
BigDogYJ
BigDogYJ
Earth
No I didn’t mention it prior. I actually assumed that all gmt900’s had them. Or at least I thought so. That might be wrong. Sorry. Yes it has adjustable pedals but moving them to different positions along their travel doesn’t seem to make any difference in the squeal noise. So not sure that would change it.
Sorry was doing family stuff today so didn’t test without the vacuum hose plugged. I’ll try tonight after baby is asleep.
dkad260
Based on the duration of the sound, I agree it sounds like a ruptured booster diaphragm. I can't think of anything else other than the check valve.
BigDogYJ
BigDogYJ
Earth
Before I had a chance to test any further with this, I had to take care of the pulsing brakes which turned out to be due to previous work done incorrectly. So I ended up replacing pads and rotors and rear calipers. the numskull who did the brakes last installed the pads opposite of their intended position (inboard vs outboard) so the outboard pad (had two stand off pegs on the backing plate of the pad was pressed against the piston and deformed the piston which damaged the piston seal :mad:. Front were ok likely because the twin piston design doesn't interfere with the the backing plate surfaces (although lacking any grease -- frozen pins), but the rear single piston were ruined. So new Akaebono pads and Quietcast rotors all around and new rear calipers and all lubed up. Brakes feel great, btw the squeal noise from booster is gone. I can't get it to replicate now at all and brakes feel fine. Just did a 70 miles mountain road drive this past weekend and feels so nice and smooth. It's hard to find good work unless you do it yourself. For now I guess I can mark this as resolved. Maybe it was just the boosters way of saying fix the damn brakes from the last idiot. noted.
dkad260
Glad to hear it's resolved. Not to jinx you, but if the rears start making noise, check the fitment of the pads in the bracket. My last pair of Akebono rear pads had a loose fit, Akebono replaced them and the new pads squealed as well.
The tabs of the pads were slightly smaller and rattled in the bracket. Akebono replied to my concern and confirmed the size difference.
Really? Lol. Well, I went with Pro Stop and all was good again. Akebono wouldn't refund my money so never again. Obviously a design flaw but water under the bridge now.
BigDogYJ
BigDogYJ
Earth
Bummer, I'll keep an eye on them. haven't noticed anything so far. that previous set was squeaking but it was more or of a creaky noise when applying the pedal even at a stand still so not the pads themselves squealing agains the rotors just the hydraulic pressure applied by the caliper which I can only assume now was due to the a**backwards install and messed up pistons. I have power stop on my 2000 K1500 and happy so far with those (only about 3k miles). I'll update here if anything pops up. Thanks
