Brake Buying advice
ladorn45
Hey Guys,
So I finally bought a house with a garage. So now I can do more work on my car rather then take it to a mechanic. I noticed my rear brakes making the grinding noise so it is time for new breaks possibly new rotors as well. My question here is it worth spending a little extra on better rotors like brands powerstop or will anything from autozone or pepboys be enough. I am willing to spend the extra money on better parts if it is worth it. Any advice would be appreciated. Also if anyone has recommendations of pads and rotors that would be awesome as well. As always thank you for all your help guys. 2001 tahoe with stock 16s
HiHoeSilver
Away!
Chicago
Hey Guys,
If you had 17" or bigger wheels, you can bolt on the fronts from the NNBS with a 13" rotor and two poison caliper. As for the rears, yours are already better than the NNBS, so stick with stock sizes for those.
Powerstop gets mostly good reviews here. There are a couple threads complaining about them. Another popular brand is R1 Concepts. Usually the argument for upgrading rotors is to avoid the "warping" issues of the cheaper ones. It's not really warping, and there are many discussions on here regarding that as well. Some guys swear by the high end NAPAs. Whichever route you go, the bedding process is key to longevity.
L
ladorn45
Thanks I was reading about the NNBS upgrade but going to hold off on those until i need new tires and end up getting bigger rims. For now I just wanted to see what people are suggesting for stock setup.
Scottydoggs
NJ
i run nothing but R1 eline drilled and slotted with their ceramic scorched pads. put em on the hoe and they stop way better then when new. been running them for like 5-6 years on my regal too. best brand i ever used. best part is they only cost ya about 200 shipped on their ebay store for all 4 corner's, they sell full kits, or fronts or rears. best to do all 4 cause theres a break in for them, id hate to do it to old pads cause you only did one axle.
just put a set on my friends 300c. hes like i need to watch i dont take my teeth out on the steering wheel. so made another fan of them for sure lol
L
ladorn45
I am most likely going to swap out all four rotors and pads, and hopefully the calipers are still good. Do you have the link to the r1 concepts?
HiHoeSilver
Away!
Chicago
If you're doing a full stock kit, their eBay store is good. I just called them to build my Frankenstein kit and sales on the phone was outstanding.
L
ladorn45
Thanks. I saw that link but they where so much cheaper then the companies site that I thought those might be the knock offs. Once again thanks for all your advice
adriver
IMO compare prices/options on rockauto.com (which will probably have the most options in one place), r1 concepts, and autozone/ whatever your local parts store you like to use. I would bet rockauto or r1 concepts is probably cheaper, (at least before you add in shipping costs). Rockauto is a vendor, and usually posts a discount code in there forum for 5% off.
You have to consider how you drive for what you want to upgrade too. Blanks have slightly more surface area and are best for "country style driving", where you're not on the brakes often, and its more important to have that one, slam-on-the-brakes stop such as when an animal jumps in front of you where those several feet could make a big difference. For most people they drive city-style: stop and go traffic, rush hour where you try be a little more "on top of it", lots of quick brakes without giving your brakes plenty of time to cool off every time. If this is how you drive, slotted keeps more rotor surface while allowing heat to escape through the slots, or drilled rotors allow heat and gasses to dissipate through the holes into the vented center of the rotor to help stay cooler. Cooler brake rotors and pads won't fade (as quick) or even worse, get cracked pads or warped rotors (like my stocks did). The Tahoe is a heavy vehicle, and if you drive even "semi-aggressive with stop and go traffic", you probably do want to upgrade to better suit your driving style.
Just cause I like to hear my self talk, while were at it, make sure your fluid is good or plan on changing that too if it hasn't been done in a couple years. You can take a quick look... it started out clear. Last, not a big deal if you don't, but its not much more to do your parking brake while you are in there. If its not holding well, its only the difference in having the rotor off as long as you're there. Its just something else to throw at you for you to consider to be prepared.
SnowDrifter
Sasquatch Country
I'm using the napa epoxy coated rotors and akebono ceramic pads on mine. Hydroboost brakes.
NNBS front rotors/calipers, though these only just clear 17" wheels.
Can do 5-6 stops from freeway speed without fade. Or 1 from full speed on a slight down hill (fades slightly right before the stop). They're pretty heat soaked after that.
Plenty enough for daily driving. But it would leave a lot to be desired for track or high HP use.
I can't comment too much on longevity. Only have 25k on my set
Scottydoggs
NJ
these R1 brakes tend to like the heat. never felt em fade out. only during the bed in procedure. and r1 has you beat the tar out of them poor pads and rotors, says if you see and smell smoke,,,, your doing it right lol im ad-libbing, but it does say its normal.
CountryBoy19
Southern Indiana
I'm using Raybestos EHT3 (Enhanced Hybrid Technology) pads and Raybestos corrosion coated rotors along with Raybestos new-manufacture Optical Calipers w/ a lifetime warranty. So far I'm happy. I did notice a small bit of squeal the other day but I think it was a weather thing because that's the only time I've heard it.
That being said, bedding brakes is unnecessary on "daily driver" brakes. Yes, you can get slightly better performance out of semi-metallic brakes if you properly bed them, but that performance is unnecessary in most applications except track use. The reality of it is, on clean dry pavement I can likely break my front wheels loose if I put the pedal to the floor (I also have the hydroboost brakes which makes a little difference as well). IE, roadway traction is the limiting factor of stopping in most cases, not braking power.
CountryBoy19
Southern Indiana
I disagree. Bedding in is an integral part of the installation process.
That's why we see the OEMs and dealers out there bedding brakes after they're installed right?
There is ZERO value to bedding ceramics so forget about that from the start; ceramic pad material doesn't transfer to the rotors like semi-met does.
Never mind the fact that many brake manufacturers only offer bedding directions for their high performance (track use) brakes...
IMHO, many on this forum have an obsession with performance brakes that will never perform to their design bc they'll never see track use. They'll never be paired with performance tires and performance driving surfaces that can take advantage of the added braking power. Most of them install them bc they think "more brakes, more better", without any real understanding of brakes. More expensive=better right? Sure, but if your tires can't hold traction at the higher brake power then any additional brake power is wasted. That may be an unpopular opinion bc it means you wasted money on brakes, but it's the unfortunate truth.
Don't get me started on drilled & slotted rotors. Most that spend $$$$ on them have no idea what the pros & cons of them are. They just know they sound fancy, look cool, and cost more so they must work better...
SnowDrifter
Sasquatch Country
You're pushing a straw man pretty hard associating a bed in process with performance brakes then saying performance parts don't offer a street benefit, therefore bed in is of no use. Can't say I appreciate that.
Can't speak to OEMs. But every dealer I've seen has some sort of bedding process here. As do indy shops.
The process is as much for an even deposition of material as it is checking the work was done properly and verifying quality of parts. Every time I do brakes, whether it be for myself someone else's car, I take it for a test drive and beat the piss out of them. I'll hand over they keys once I'm satisfied everything works properly. Last thing I need is a call that someone ended up dead because pad material separated or something. Looking at you oh-oh-oh-ohshittyautoparts. Wouldn't have found that without a thorough test drive, or bed-in, as it's commonly referred to.
CountryBoy19
Southern Indiana
Straw man? I'm just pointing out the unpopular facts. Justify your expensive brakes all you want. But unless you're running performance tires and driving on perfect pavement your tires will lose traction long before you reach the limitations of normal quality brakes (we're not talking auto-store discount brakes here). Very few people have EVER put their brakes all the way to the floor. They may think they have but they likely didn't.
A test drive to ensure functionality is one thing, but I doubt the motivation for doing so is to "bed the brakes". It's to reduce liability by ensuring proper function.
Like I said, if you're installing ceramic there is no such thing as bedding. Ceramic doesn't even transfer to the rotors like semi-met does. And IMHO, only place semi-met belongs is on the wheels of people that like the cheap auto-store brakes or those that are buying performance brakes. Semi-met performs a bit high than ceramic but makes a dusty mess doing so. I don't care for the dusty mess so I went quality ceramic on my brakes. They stop better than the OEM brakes and I can break traction with them on dry pavement. I don't need high-end performance brakes.
That being said, the theory behind bedding brakes: Hard stops that get the rotor and pad hot transfers semi-met pad material to the surface of the rotor. The coefficient of friction between this glazed coating and the pad is slightly higher than the coefficient of friction between the pad and bare cast-iron. So you get slightly better brake performance. Why only slightly better? Well, this glaze only partially covers the rotor, the vast majority of the rotor is still exposed cast iron. If the pad formed a perfect glaze over the rotor then the cast iron would never be exposed to the pad and would therefore never wear, yet we see wear on rotors with semi-met pads still don't we? So this "glaze" can only work where it is, and that is in microscopically scattered "shotgun pattern" across the rotors surface.
Don't take this from me, look at brake manufacturers and what they say. I'm just being realistic. The truth is, stopping your vehicle can only happen as quickly as the weakest link will allow. On OE brakes the brake pad is normally the limiting factor on dry pavement but it's closely balanced with the friction of the tire on the road. That's why when you see them doing stopping distance tests the tires chirp a bit as the vehicle comes to a stop. In this case adding more braking power just makes the ABS work harder, lengthening stopping distance. I don't know how else to explain this...
I will say that people running oversize tires could likely benefit from performance brakes because of the torque difference due to the larger tires. However, in many cases it doesn't take much more brake to accomplish the task and it can ofter be accomplished by choosing a better pad material. That pad material still may not benefit from bedding...
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
L
ladorn45
Hey Guys,
I appreciate the passion. I really do but my goal was not to start a brake war lol. Everything everyone here has said has been very insightful. I never worried about what brakes to get cause the mechanic always gave me a price and that was that. Now that I am saving money on labor and doing it myself i have the choice on what parts and the extra cash to spend on better pads if justified. The style of driving i do is mainly long distance highway driving, but there is alot of stop and go braking to get out of the city area to get to these highways. Also the occasional slamming the brakes hard cause of some jack ass that realized he missed his exit or just driving like an ****** (unfortunately this happens more then i would like). That being said I do put some strain on my rotors and brakes. As of right now I had all new brakes and rotors and calipers done about 3 years ago and only put about 10k miles on them. Now I am hearing a grinding noise coming from my rear brakes that comes and goes but hear it more after a longer drive. Obviously need to inspect this and see what it is but wanted to be prepared so when time comes to get new brakes and rotors I can get something that works best for the money. I am okay paying a little more if that means I can get rotors and brakes that might be considered overkill for my overall driving but that one instant where it can come to play and save me or my loved ones from harm. Then to me it is worth the extra cash. That is one of the reason why i have no problem paying more for crucial parts like brakes and tires.
Scottydoggs
NJ
these rear calipers got a rep for sticking and not letting the pads go free. 10,000 miles is pretty quick to wear out pads.
id inspect the rear calipers before buying new parts, ( this mean take them off push the pistons back in, see if they go back in smoothly) you might need to rebuild, or replace the calipers as well as rotors and pads.
the e brake work as it should? they can fall apart and drag, theres a small drum brake in the middle of the rear rotor how the e brake works. need to remove the rotor to see them.
X-ray Nerd
