Blown belt and heads?
KPOD
Michigan
Driving down the highway tonight, had the belt completely blow. Pulled over after I noticed the battery light and check gauge light turn on in the dash. Noticed then the fan wasn't spinning and the temp gauge was all the way over to the red. Limped it home approx 1 mile from where I noticed the temp gauge heating up and had pulled over, hoping I didn't crack a head from overheating. When I pulled over it cooled down a little bit, but was still near the red. Do you think driving it a mile with neither the water pump or fan blowing would cause a head to crack? No coolant leaked out, it's a Vortec head, and it was 29 degrees out tonight.
livingez_123
Sandy, OR
The smart thing to have done was parked it, and tow it home. BUT, you have might have been lucky with the ambient temp being so low and going very slow. If it didn't boil over into the overflow, the least you could have done is maybe shorten the life of the heads/gaskets. Put a belt on and drive it. you will have your answer soon enough.
Gzes
the drifting 2dr
Wichita tx
I had my belt snap on the highway and drove it like that about a mile on the highway. When I got there it was almost overheating but didn't. I was lucky and you might be too
retorq
Kingman AZ
You more then likely cracked a head. Those Vortec heads have a thing casting near the water jacket between where the 4/6 and 3/5 exhaust ports sit. If they are run for any amount of time with no water flow those jackets will vaporize the water and turn it to steam. It's game over at that point ...
K
KPOD
Michigan
I'll do an oil change tonight and check the oil for coolant, that should be a for sure way to tell. No coolant in the oil, then I'm good.
ezdaar
Chat Troll
Redneck central, Aka Houston
just because no oil in coolant, doesn't mean the head material between the intake and exhaust valve didn't crack.
Need to perform a leak down test to find out.
livingez_123
Sandy, OR
put a belt on it and drive it, you will find out one way or another. I wouldn't even bother to change the oil yet.
kcb37
I would agree check the oil to be sure, but put a belt on and drive.
K
KPOD
Michigan
Drives just like it should, no overheating or funny smells or noises. Will change the oil tomorrow since it's due for a change anyways, and hope for the best :happy160: Turns out the belt tensioner blew or something, and that is what took out the belt. So I had to pick up a new $20 tension wheel as well.
Candielaine
