Black ashy debris in coolant reservoir
CTUBS8732
San antonio
Radiator blew and limped it home. Overheated a little but not all the way to the max. Replaced with a 4 row aluminum Radiator and now I noticed at highway speeds my temp stays at 154° and at idle it warmed up to about 226° then fan kicked on and temp went down to about 195° and slowly rose back up, i have black specs floating around. I smeared some and it looks to be ashy not so much as greasy or oily. What could the stuff be? Also I was having trouble burping the system. I did not flush it as I should have done it. I've done some research and all I can find is blown head gasket but it's not oil or at least I dont think it is. Its like little black specs that look like black ashes floating around.
CTUBS8732
CTUBS8732
San antonio
If you suspect a blown head gasket try using one of the testers for exhaust gases in the coolant:
Got some of the debris on a paper towel seems like it's small specs from the heater hose. It smears but it's not oily or greasy.
kikeap
