Belltech 2/4 drop
crew chief
Puyallup WA
I just installed the Belltech 2/4 drop yesterday that I purchased from Tony.
The installation was fairly easy and took about 3 hours. I cut the bumpstops as Tony indicated and set the air ride links at 3". There is a little rub on the inner fender with the wheels turned hard.
Here is the before and after measurments:
LF 35 3/8" 33 1/2"
RF 35 3/8" 34"
LR 37 5/8" 35 1/2"
RR 38" 35 1/4"
NathanJax
Vacation Nathan
Jax, Fl
Good looking Denali!
I'm guessing 22"s?
C
crew chief
Puyallup WA
The RR started out higher than the left with the factory springs installed. These measurements were done right after the drop so I am hoping the rear springs will settle a little bit. The compressor seems to kick on more than before so I am going to adjust the links to 2.75" and see what happens. The ride is great for a lowered vehicle.
KMeloney
That sounds high with no spacer. You definitely need to shorten the links. I know Tony and I have gone back and forth on this, but I think that the links need to be shorter.
C
crew chief
Puyallup WA
After the drop and front end alingment my wife was driving down the freeway and experienced a "death wobble" in the front end. It has only happened once so far. Have any of you had this happen or have any idea what caused this?
C
crew chief
Puyallup WA
ya, like the video. The steering wheel was moving back and forth. I'll pull the wheels off today and make sure everything is tight.
2011Tahoe
Wa Coast
Crew chief-- have you shortened the links yet? My compressor seems to kick in alot more and i have been debating on 2.5" or 2.75" links let me know what you decide. And how it helped. Thanks.
C
crew chief
Puyallup WA
I have not had a chance to change the link lengths yet. I am out of town until next week. will update with the results as soon as I get back.
26slate
Irvine
check the pitment arm/ have the alingment done had a old 1500 2wd lifted do that back in the day my pre runners used to do that and my old 05 4wd f250 did that after i lifted it cuz the alignment wast rite
Denali0229
FL
Looks good. What year is your Denali? I have the exact same truck but 2007. I'm thinking about dropping it a little after I get a set of 22s. Your pic really helped me visualize what mine will look like.
worleytrev93
