alternator replacement feedback?
papaman
so my alternator has begun to make noise from the unit itself. figure i should go ahead and swap it out before something bad happens.
i have the 160 amp RPO KW1 unit, and the acdelco replacement is a couple hundred dollars..... :(
anyone try a duralast unit? particularly DL1912-6-11? or am i worrying too much and should just grab any replacement?
NASTY GM
Nor Cal
I'm running the Mechman 370 amp which is awesome, but it retails for about $700 :insane:
RED TAHOE LS
Rossville, Georgia USA
Unless you need the extra power outage, I would go with the Delco replacement, but not reconditioned. JMHO and good luck.
David g............:2cents:
check rockauto, they probably have the best price on a oem one, there is 5% off coupon in the vendors stickys
aye_rod
