Complete audio overhaul/replacement (install thread)
RichardCranium
Mebane, North Carolina
Figured I'd share here, since I updated this install in my own build thread in the PPV forum. Nothing ground breaking by any means, but showing what I decided to go with since I wanted "better than stock" audio.
First thing I did was choose a head unit. I wanted to use Android Auto, so it narrowed down the DD head units I had to select from. I ended up going with the Alpine iLX-w650. I always had Alpine back in the day, so why not? And it had a nice touch screen, decent power output, and the capability to add a sub later if I chose. Also, the same for Alpine's own amp that mounts to this unit.
My setup:
(1) Alpine iLX-w650 Android head unit
(1) PAC tone interface box w/ SWC
(1) CarXTC DD installation kit
(1) Alpine KTA-450 Amplifier (45w RMS x 4ch)
(4) Kicker 43DSC6504 6.5" Coaxial speakers
(1) Kicker CXA400.1 Sub amplifier (400w RMS @ 2ohm)
(1) Scosche 8ga Amp wiring kit
(1) Kicker 48TRTP102 Sealed subwoofer box, Down-firing 10" CompRT sub
When I installed my head unit, I went ahead and ordered the factory USB tray for the bottom, and plugged my USB input from my head unit into that port. I also decided not to run the microphone up into the factory overhead provisioning, instead I cut a port out in the bottom pocket and have the mic peaking out. From feedback from folks directly, it sounds great from there. I did this mainly because the overhead provisioning for a mic is susceptible to cabin noise, while the mic sitting in that pocket has a more isolated radius to pickup sound. Apparently it works well, so its permanent.
RichardCranium
RichardCranium
Next on the agenda was replacing the 4 door speakers. This is a PPV, so no a-pillar tweeters. I could have added them, but don't feel I need them.
After doing some research and narrowing down my choices for the shallow depth application we face, I decided on these Kickers.
The OEM paper woofers. Honestly, I can't believe they lasted as long as they did. They didn't sound terrible, but obviously weren't great. RIP dudes, y'all out.....
The factory front and rears door speakers are molded into a plastic bucket. There are aftermarket brackets available, but why when you can just cut the factor speaker away pretty easily and use this bucket?
Factory versus its replacement......
RichardCranium
RichardCranium
Profile of the new slim speakers.
Simple to remove the woofer, just break the spokes coming from the magnet, or cut them. Then just trip down the lip around the face of the bucket like I've shown below. Pretty doesn't matter, no one will ever see it. Just get it trimmed flush, and be careful not to break the plastic.
New speakers mounted in the factory buckets, using the screws the speakers came with.
RichardCranium
RichardCranium
That Alpine head unit is 16w x4 RMS, so even with the better speakers.....it sounded so much better. But not long after I installed the head unit, Alpine released a newer version of the amp that is made to pair with this head unit. The new amp offered more power, plus DPP. I grabbed it a couple months after installing the head unit, and a few weeks after installing these Kicker door speakers.
The amp mounted to the back of the head unit, bolts right up. I had to modify my DD install mount for the head unit a little. Originally I cut it to accommodate the wiring harness of the amp, but upon test fitting......I found the wiring harness really needed to be routed under the amp and out of the bottom side.
Final mounting position for the harness shown here.
Full rear view of the amp.
The amp does have gain, balance, and crossover adjustments. The only downfall to the amp being mounted in the dash is not being able to access this stuff easily. But this isn't a competition install, its just a factory upgrade. I selected the crossover settings to prevent the 6.5's from trying to produce any low bass, adjusted the gain with the radio on, and reinstalled it. amp4.jpg
RichardCranium
RichardCranium
Since installing the head unit, new 4 door speakers, and an amp for those door speakers.......I've been waiting to add a subwoofer. I debated a few ways to add one in a subtle application, and with the limitation that I am not trying to impress anyone while I cruise the strip......this is for my own enjoyment when I want to crank the volume. With that said, I decided to go with this pre-made Kicker enclosure. It has a 10" CompRT Sub and a 10" reFLEX passive radiator. Essentially they work together in this sealed box, and produce pretty incredible bass that sounds like its coming from a huge ported box.
This is the box, standing on its side so you can see the speaker.
This is actually how the sub sits, below.
I got home and got right on the install, I dropped some coin for this stuff and I wanted to hear it.
Head unit out, connecting the RCA's and remote wire.
Front seat out
RichardCranium
RichardCranium
Rear seat out on the driver's side.
Seats came out to make it easier to fish the RCA's, power, and remote wires through. I ended up pulling the power wire through a factory grommet on the firewall, under the brake booster. From there I tucked it under the dash and through the center console.
I taped the wires to a long screwdriver, and actually inserted a 4ft long prybar under the carpet to help pick it up out of the way.
I mounted the amp over the carpet seam right in the middle, under the back seat. I grabbed ground on the seat chassis, and the cables run under the carpet were cut to length or pulled through sliced in the carpet to keep things nice and neat.
Pardon the mystery stain......not sure what it is, how it got there, or when this happened. Blame it on drunk girls, the likely culprit. :)
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
My setup:
Looks great! I really wish I had those simple dial controls for my HVAC. I can't stand the digital ones mine has. I wonder if they are interchangeable?
Great write-up!
Our collective knowledge base has been increased.
I definitely know what you mean, when you talk about designing and installing an audio system that sounds great to you INSIDE the truck, and NOT designed to set off car alarms or announce your arrival from 2 blocks away.
Koop
I second this question... could you share if you purchased the hvac control unit elsewhere?
kbuskill
NE. FL.
The manual HVAC controls are NOT compatible with the Auto/digital controls.
992dr
Eastern N.C.
You are so detail oriented and always like reading your threads.
My door speakers have sh*t the bed, I'll be going with the same ones.
I have tweeters in my PPV and will leave them alone as they work fine, they are the only speakers that work haha.
Did you upgrade your rear storage section speakers as well?
Geoby00
I just bought a 2014 K-9 PPV, and am looking to put a nice system in it. I’ll use this thread and base my system off it. Thanks for the detailed post!
RichardCranium
RichardCranium
Update:
I do not recommend this head unit, and in fact Alpine's customer service can suck it too. I've had lots of problems with this head unit, between using USB storage for music and the 'random' not working properly, to channels intermittently working/not working (sometimes the front speakers drop, sometimes the left channel drops, sometimes the right channel drops, sometimes all 4 door speakers don't work, and there is no consistency or any way to duplicate it), and Android Auto has a mind of its own, which might not entirely or at all be Alpine's fault.
If a Moderator sees this post, can you copy/paste this to my OP? I'd really like to pass the buck for anyone to steer clear of this head unit/amplifier combo. It sucks to have to say it, since I've been using Alpine since the 90's.
Drewphil
