AirBag Sensor Code B0083-39
BSarteSr
My '07 Yukon XL Denali is throwing out DTC B0083-39 which is supposed to be the left front airbag sensor.
Anyone have a diagram where this sensor is?
I know it is going to be tucked way up under somewhere that is a PITA to get to!
Moderator
People's Republic of Colorado
Eric show you in the video. There's a drawing here:
BSarteSr
BSarteSr
Nope, do not see a diagram anywhere!
intheburbs
SE MI
They're not cheap, but replace them both. If one died, you're on borrowed time with the other.
They're not too much of a PITA. They're on each side of the radiator support crossmember. You can get to them from underneath. Easiest to remove the splash shield first.
I had other things I was doing, so I removed the front clip... Sensors circled:
There are several good videos...
BSarteSr
BSarteSr
I had other things I was doing, so I removed the front clip... Sensors circled:View attachment 366677
Thanks!
Escalade2007
