air bag brackets etc...PLEASE HELP ASAP
thor1125
orange county
i have all my parts to do the air suspension on my tahoe except the brackets foR the front and rear... i have no idea which brackets to buy.. could you guys point me in the right direction and where to order them from ... im looking for either BOA or bag behind axle brackets for rear.. and for the fronT i have nO idea which ones to get... also should i take the torsion bars completely off or just adjust them all the way out to as low as they will go ?(WHAT WILL HAPPEN IF I LEAVE THEM IN) thanks.. info asap would be appreciated so i can get them ordered in the next couple days to start installing.. also anyone else have any pics of their install or how they mounted everything... thanks again ..
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
I have the Air Ride Technologies air ride kit with the BOA and shockwaves in the front, there really is no bracket for the front unless you go with aftermarket control arms because you can't weld on the factory ones because of them being cast aluminum i believe....here is the link to the product with instructions and instruction pictures....
Rear.. http://www.ridetech.com/shop/suspen...00-2006-chevy-tahoe-coolride-rear-system.html
Front.. http://www.ridetech.com/shop/suspen...-2005-chevy-tahoe-shockwave-front-system.html
---------- Post added at 10:33 AM ---------- Previous post was at 10:33 AM ----------
is the truck in you avatar not yours???? cus i know the got that had that truck is on GMFS
thor1125
thor1125
orange county
no the tahoe in my avatar is not mine... I wish ...ha ha ha i love the way it looks... i wish i could find more pics of it though,..
TEXAS DEMON
with a vengeance
texas
fiirst off are layin the truck or just changing the oem suspension for bags?
TEXAS DEMON
with a vengeance
texas
thas the best a way to go and just weld a bag plate on top of the c/a.
thor1125
thor1125
orange county
tahoe is 2wd... and no im not trying to lay the tahoe .. would have to do alot more extensive work such as c-notch tub etc... what brackets do i need to get that mount the top of the bag to the frame... pics wouldhelp and place to purchase such brackets.. thanks guys.. i know i could weld a plate to the djm LCA but already have the whole airride setup except the brackets.. dont have the money to purchase front arms right now but atleast wanna get this stuff on the tahoe now..
groundscr8pr
flaccid member
scarborough maine
i would be really interested to see those front brackets work. they look like they are for a coil front end. maybe they bolt to the shock mount. i dont see how they would work tho.
thor1125
thor1125
orange county
i have bags ... i didnt wanna go the shockwave route plus the cost of the shockwaves is expensive and i have read that they ride kind of stiff and not enough play in them ..
TEXAS DEMON
with a vengeance
texas
so you are better of with the brackets from coolcars.com and for the rear use the behind the axel brackets.
that way you dont have to cut up the floor
thor1125
thor1125
orange county
i have a set of the re7 for the front ... gonna be running 1/2 inch lines ,2 viar 480c compressors, 2 5 gallon tanks, fbss switchbox
briannorris
