AFM DOD Delete 2015 yukon 6.2
yukon2015
I will be purchasing the AFM DOD DELETE KIT.
Which one should I buy?
Camshafts included?
Can't we just replace the Only lifters without springs?
Does the ECM need to be changed as well?
Sam Harris
Texas
I don’t have personal experience with this, but I’m sure others who have will chime in.
I’ve been very happy with my parts (cam, heads, and various supporting parts) from TSP. Yes, you’ll need a new cam, and to program the ECM. So personally, I’d get a tune, and also springs, retainers, wear parts in the head.
Here’s an example:
Y
yukon2015
Here’s an example:
thanks sam
I'm doing a lot of research.
what do you think??
Can this plug stop the lifter from moving?
Awesome easy work!
Sam Harris
Texas
thanks sam
what do you think??
Awesome easy work!
Sorry, but I can’t help with that. I’ll say the website / grammar, etc.., gives me pause.
MobileHomie
I just had the AFM Delete done by a performance shop.
Regarding the springs, and lifters, always use new lifters with a new cam and new matching springs will have the proper load for the cam. This nothing new and not the place where short cuts are taken. Blocking the oil ports has to do with eliminating the AFM lifters, and a new, lower pressure oil pump is required.
NewbWrench
Do you plan on changing your oil from the 0w20 after the delete? I just got the digital delete from KZM and haven't had to change oil yet but it got me wondering.
Y
yukon2015
Thanks everyone
I ended up replacing the camshafts and lifters.
The camshafts and lifters were shaved. This is what caused the misfire
and Deleted AFM DOD with HP tuner.
Rough idle and strange noises are gone.
I feel like it's off to a bad start though.
I think it needs to be tuned with some kind of HP tuner.
Y
yukon2015
camshaft shaving.
Tupapi
