http://www.youtube.com/watch?v=Jo76ylqgUR8&feature=youtu.be
This video I made shows how to fix intermittent ABS and Brake dash lights on all Chevrolet vehicles with the Kelsey-Hayes 325 EBCM module. You may have code C0265 "Electronic Brake Control Module Motor Relay Circuit." The fault is usually due to corrupted solder joints on the circuit board to which the motor relay circuit is connected and is easily repaired with additional solder. The warning lights are intermittent whereas the poor solder joints result in brief communication interruptions with the relay circuit. The warnings will extinguish when reset (turning the vehicle off/on) and will illuminate again once the circuit loses its communications path. (If it were a bad relay, the warning lights would most likely not be intermittent.)
My ABS/Brake lights got to the point where they would come on after less than a minute of driving. I have now driven my truck over 400 miles without the lights coming on after performing this repair.
Merry Christmas!!
Merry Christmas!!
