97 suburban with bad transmission...
alaska_guy
Alaska
For under $1000 would this be worth picking up?
Clean body, clean title, rebuilt engine, red leather interior. Owner said I can drive it home it just has issues shifting into 2nd or 3rd sometimes.
Curious what a transmission would set me back.
I'm looking for a new project.
If everything else is good, imo worth it. You might luck out with the trans--might be an easy fix. Not sure with Alaska prices, but here in NJ a used trans will run you somewhere around $500 without install. Post some pics if you have any.
alaska_guy
alaska_guy
Alaska
Not a huge fan of the red interior, but not a deal breaker. I like the white exterior.
alaska_guy
alaska_guy
Alaska
I can get a silver suburban in just as good shape without a bad trans for 3k but it's silver and I don't like the rear fender flare deals.
My plan is to lift it.
https://anchorage.craigslist.org/ctd/d/1999-chevrolet-suburban-1500/6751818574.html
Did they make a white exterior suburban with grey interior? That would be my ideal choice.
Though, if I could do something like this with the silver one this may work....
I guess I will check the silver one out tomorrow.
east302
Mississippi
Yes, gray or beige was probably more common than the blue or red.
Edit: I saw your other thread on towing and that you have a V10 F250. These half-ton Suburbans are going to be no comparison to your current tow capacity if that is what you intend. A 3/4-ton with the 454 would be ideal. The later generation (2000+) with the 6.0 or 8.1L in the 3/4 ton improved on things as well.
Here are the tow ratings for a 98:
alaska_guy
alaska_guy
Alaska
Thanks for the info. I tow about 4000lbs max. I would be keeping my F250 since it's paid for. More or less looking for a hunting/camping type rig that will tow my side by side.
CKendrick
