6x9s where the 4x10s were
SeriousSide97
guys whats up. Listen I no its been talked about before here but help me out.
i wanna throw my pioneer 6x9s in the rear roof area where the 4x10s use to be. How can I accomplish this easily and cheap. thanks
norcalpilot
sacramento CA
Very easy. Just double check the depth on the 6x9s. Some fit some dont (if you want to keep the stock look. Use a dremel to slightly mod the cavity. Plenty of write ups in here on different ways and techniques just use the search. Good luck
S
SeriousSide97
yea there a little to deep. gonna need a adapter so where can i get one for cheap. Wasnt there a guy here who use to make em?
96ProCompTahoe
IN
I'm no stereo guy but plywood and a router? Maybe a sheet of ABS and router it?
x2 if you don't have a router you can do it just as easily with a jig saw. have done siome spacers for a previous ride a while back out of some scrap plywood and they worked fine.
basically the same thing with abs or whatever you want to use.
96GMCYukonGT
i unbolted the plate cut it out to fit the 6x9s and bolted in back in and then bolted the 6x9s in there a little to deep but the cover fit back over still
navi243
San Antonio, TX
Does anyone know what depth will actually fit?
I am trying to pick a 6x9 3-Way prefferably Infitinity...
Thanks for the help in advance
WITCH1975
