6/4 rcd lift, need to lift rear more 95 hoe
4PaPaG
Las Vegas
I have a 95 yukon 4x 4 door, i bought it with a RCD 6/4 lift, the rear sags a little to much and i wanted to lift it roughly 1.5 inches to level it out. I read that if the Yukon gets anything more than a 5" in the rear it will need drive shaft work...does anyone have any input on putting a ad a leaf spring 1.5 to 2"..
Thanks
After reading another post, should I go with a total spring replacement for the rear to bring it up to level? (RCD lift I have has blocks)...
4PaPaG
Las Vegas
Some shots
99COOP
Retired
Chicago, IL
the spring will get rid of the axle wrap your getting w/ the blocks, but they will cost you a little more. You can put in an AAL to the spring pack and you will get 1-1.5 inches out of that, the only downside will be that it rides a little stiffer. You shouldnt have to worry about the driveshaft on a 4dr, they are much longer then the 2 door driveshafts which often need to be modified. You will have more then enough length to work with on your stock shaft, and the ujoints wont run into any binding issues.
4PaPaG
Las Vegas
Thanks for the info, the AAL's I found were ($70 - $90) so I might go that route and if it is to stiff I can get some springs later on down the road..
thanks again,
G
99COOP
Retired
Chicago, IL
yea people complain about them being too stiff, but you didnt buy a Tahoe expecting it to right like a Cadillac so i say go that route for the time being and cost. I ran that set up and had no problems.
bowtiefreak
No Quarter
Near Philly
Springs nver hurt. I ditched my block days after I put it on for a true 6" spring in the back. I am much happier with it. As Coop mentioned, the drive shaft should be fine. The 2 doors are the problems. I did need to work on mine.
bowtiefreak
No Quarter
Near Philly
needs to be longer and depending on how high you go a CV shaft won't hurt to help reduce the angles on the joints.
MTN_KDA
