Air ride repair question
BainMan
My question: Why does the T1 Air Ride system use nitrogen in the reservoir, when the compressor uses air from the atmosphere?
From the factory service manual:
The compressor draws air from the atmosphere or reservoir, compresses and dries and supplies it to the Air Suspension Controller. The compressor exhausts air to the atmosphere from the Air Suspension Controller.
Also from the factory service manual when replacing an air shock:
Using CH-52667 Air Spring Inflator and the shop nitrogen tank, fill the automatic level control air supply reservoir to 16 Bar (232 PSI).
Is the nitrogen required when changing out an air shock? Is it more necessary when the entire reservoir was empty and must be refilled? My initial guess as to why nitrogen instead of air is to not put a bunch of wet shop air into the system on initial fill.. Any other reason? Won't most of the nitrogen be expelled within the first few months as the compressor inflates and deflates based on vehicles auto levelling over time?
Background: 2021 Yukon XL Denali - rear sag after sitting. 2.5cm droop after 13 hours. Full droop (4.5cm) noted at 4 days, but was probably sooner, that's just how long we were gone . Passenger side seems is worse. No leaks apparent at compressor/valve after soapy water test. Planning to pull the air shock off and check for leaks at the bladder, but the "boot" makes it difficult, the shock will have to be completely removed, disassembled, and filled with air before it can be tested.. With the nitrogen requirement, trying to determine if I should just let a shop handle it, but not looking forward to turning a $300 parts bill into $1,200(?) parts and labor...
rlhmarines
Senior Member
Marine Corps Supporting Member
Just an uneducated guess here but it could be to prevent moisture in the system and for a more reliable and stable operation.
Edit:
Quick google search on the T1 air ride system below.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Using nitrogen in a system that constantly inflates/deflates based on the need, would require and on board nitrogen tank.
You can fill a balloon with helium, but when you let it out, unless you added helium back in, after a while, it’s only air….
BainMan
BainMan
Thank you all for the comments. I suspect that if I had an inline dryer on the compressor to prevent moisture I'd be alright..
I've seen it referenced as a closed loop system, but later described as pulling and venting from outside air. I just wanted to make sure I wasn't overlooking something.
Now, does anyone know how to 'couple' to the shock to add air without the $1,200 specialty tool (CH-52667 Air Spring Inflator)? I saw in a comment somewhere (this forum or youtube) that it's similar to an R-134a refrigerant lineset adapter, which I have! Wondering how to adapt that to an airhose though, if it is even possible..
Or do I even need to prefill the shock like the manual says, and just cycle the air compressor 30 seconds at a time until the system is fully pressurized?
Chitragupta
I have a Ram 1500 with air ride suspension and it’s a closed loop system with a one gallon hot dog tank. The gas is 100% nitrogen and the guys in cold climates have issues if any moisture gets in the system.
The guys who were servicing their own systems were using HVAC adapters they found on Amazon for plumbing their Ram system into a bottle of nitrogen.
Sorry I can’t give you the part numbers but if you surf over to 5th Generation Ram and scroll though the air ride threads you might find the adapter.
thatboy_eddie
