6.2 removing/ replace crankshaft w/o engine removal?
Cleandenali31
Pennsylvania
#1is there a way to get to the crankshaft and remove it without pulling the engine? Possibly pulling the tranny? 6.2l 2007 Cadillac Escalade.#2 do the pistons need removed to replace the crankshaft? The crank pulley got put on either not straight or the bolt cross threaded and even a 600ft.lb impact can't back the bolt out. So now there's no way to get the balancer out or let alone the bolt. Figured I'd just replace the whole crankshaft.. the oil pan is already off the truck. Any help would be great! Thanks
Buzzcut
still have to unbolt the transmission to move it back. If I were to do the job engine would come out. I guess it could be done but it will be the worst time trying to wrestle that heavy crank up into the block.
Bottom line doable but with great difficulty.
mizzouguy
Lake of the Ozarks, MO
I suppose you could unbolt the connecting rod caps through the oil pan opening and slide out the crank if your fans, rad, condensor, etc was all out, but I'd pull the engine and do a proper disassembly if it was mine. Crank is the first thing to go in when you build an engine unfortunately so it's the last to come out.
Cleandenali31
Cleandenali31
Pennsylvania
I'm assuming that since I'll be working from the bottom that the crankshaft will come right out of the bottom. I shouldn't have to remove the rad and fans. It should just drop down out of the bottom once everything is properly removed. Correct?
mizzouguy
Sorry if this picture is huge, but I looked up a crank for your truck, or tried to anyway. If the balancer is stuck on you'll have to pull it out through the front. Pretty sure you have to anyway because a crank can't be tilted out through the oil pan hole....hopefully someone else can confirm/deny lol. Also like @Buzzcut said you have to pull the tranny back to remove the flexplate.
02Lightning
Why are you pulling the crank, because of the stuck balancer? I've seen people brace the wrench and use the starter to loosen the bolt. Not that it would work after using a 600 ft. lb. impact, but at this point, it's worth a shot.
Cleandenali31
Cleandenali31
Pennsylvania
Yeah idk if I want to tackle this myself or just have it towed to the dealership and see what they can accomplish with it. Maybe they have a better technique or tools to figure out how to get it out. And if it's crossthreaded then maybe save the threads and rethread it for me and put it back on
Cleandenali31
Cleandenali31
Pennsylvania
Well if I can't get it out I might just have the dealership deal with it. But I had an idea. If I have the old bolt on right now and it won't back out after I used it to install the balancer back on. I'll just tighten the bolt back up and leave it in. Because obviously it isn't coming out. I guess that's the purpose
Brian Wilson
I'm not sure you could clear the cross member if pulling the crank. And surely putting your rod caps on and lining that stuff up would be almost impossible for 1 man. Unless you are a version of the hulk with tons of finesse
1_8TTony
I think the level of frustration getting the crank out through the bottom would be enough to drive me crazy. Plus, upon reinstallation, you will probably scratch the rod journals on the crank and dent the corners of the bearing shells.....scratch the cylinder bores . How are you gonna get an accurate torque/angle reading on all the rod caps and main caps.
992dr
Eastern N.C.
Seriously? Just thinking about doing this is making me sweat.
Not at all possible if you ask me.
PatDTN
If it's just that bolt you want I'd get a couple of fire extinguishers and an oxy-acetylene torch and throw a lot of heat on the bolt. Also note that using a giant impact on it usually just hammers all the play in the bearings, rods, etc. You want steady torque. Find a way to clamp the harmonic balancer so you can put a strong pull on it after heating. I can't remember what engine from what part of the world but I've seen flats on the balancer for a wrench on something.
YukonandtheHOE
I doubt you could get the 6th cap bolts out and doing the journal clearancing would be a utter pain! Hind sight it should only take 2-3 hours to yank the engine and life is easy street!
TejasPitt
