Bigbird
Does anyone know if there is a date that after the date they know that the engine is good with no problems or will this go on forever?
Legally speaking, it means that GM will NOT stipulate that there is ANYthing wrong with engines built after 07/01/24; thus the PRESUMPTION that everything is fine is legally in effect until proof otherwise is provided.Does this mean all engines build from July 1, 2024 are good?
Doesn’t appear promising cause of what?Engine build dates starting July 1, 2024 are supposed to be good, at least they are not recalling anything after this time period at the moment.
Does this mean all engines build from July 1, 2024 are good?? All I can say is I have 2 neighbors that have 2025 6.2l Yukon's and we cut the oil filters open from the first oil change on both and it does not appear promising!
While GM is putzing around about what to do about my 6.2l, I decided to have lab work done when I change my oil. Attached is a lab report from the 13,600mile mark taken after a cross country trip to the west coast and I changed the oil again when I returned at 15,108 miles. This data shows no internal wear...so far. Just decided to put some real science to the question..."is my engine failing"? So far the answer is 'NO".2 - 2025 OE oil filters at the first oil change, one at 500 miles, the other at 1,200 miles opened up with more metal than I would expect for a new engine. Both had similar amounts of metal in the filters
Not looking promising for engines beyond the magic fix date.
