3800 Using Coolant
Matthew Jeschke
Sahuarita, Arizona
My daily driver is a 2006 Buick Lucerne. It has nearly 190,000 miles. I've had to do very little to maintain the vehicle (list below of coolant maintenance). It seems to be using coolant and I cannot figure out how. Occassionally there will be a puddle under passenger side of engine compartment. I suspected water pump is weeping / going out. However, it's dry to touch.
Maintenance:
- New metal bypass elbows to replace plastic ones. Those had broken previous. Dry to touch now as well.
- New upper and lower radiator hoses. Dry to touch at water pump, engine, and radiator.
- Original radiator, no signs of leak on core support, holds pressure as well.
Symptoms:
- Occasional puddle of water under on driver side of engine bay.
- Fill up radiator and a couple weeks later will be down about a gallon
- No signs of water in oil.
- No smoke from exhaust.
- No signs of water / coolant leak under hood or on accessories. All dry to touch.
I hate to change the water pump if it is something else. I always like to get a good idea of what problem is before doing parts darts but seriously am completely baffled.
Fless
Moderator
People's Republic of Colorado
Rule out a head gasket by using something like in the link below. I think some auto parts places might "rent" them.
When the engine warms up, the coolant that leaks out (if there is any) can dry quickly on a hot engine and with air blowing by. Look for dry fluid traces everywhere underneath.
exp500
Put 2 Bars Leaks tabs or Gm tabs in radiator, then Think about how you want to test entire system.
Lastly a failing pressure cap can dump alot of coolant at engine shutdown. Good Luck!
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Will do, there is crusty oily mess on accessories. Maybe that is my fluid.
I wondered about that. My cap area is clean as a whistle though.
Mibd blow. I topped off last night. Opened back up cap, empty again. No fluid on floor though.
Maintenance:
Symptoms:
the best way to find the source is to put some CLEAN DRY cardboard under the engine area when you park it and leave it sitting overnight then in the morning look under the vehicle, find the wet spot on the cardboard and look directly up from there with a flashlight. if you are loosing a gallon every 2 weeks it should have some leak overnight.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Awesome thanks @Doubeleive I just pulled the t-stat (hate guessing if it's open or closed), topped the radiator off, made sure all the air was out of the system, then added to the revivor so I can tell if it sucked any in. Then set a really big clean piece of cardboard underneath that spans the entire hood compartment.
Studying cylinder leak down testing. I SURE hope it's something else. Quick gripe, I've had several of these 6 cylinder GM motors they are really AWESOME little motors except for ALL of them had pesky coolant issues like this.
Jimmyy
Minnesota
I know the early version of the 3.8 had issues with the upper and lower intakes leaking coolant.
If you didn't take it out for a good run after that and heated it up to normal temp, then you may not get any results on your cardboard.
the theory behind it is some times these leaks can happen as it looses pressure over a extended period of time or from going from expanded (hot) to (cold) overnight thereby being able to dribble out of a un-expanded place as it shrinks back to normal. a gallon over 2 weeks is a slow leak but is enough that you should be able to spot it fairly quickly.
also if it was going in the engine you should see a fairly good amount of slime under the oil filler cap even if was just burning it off. you would maybe also notice some sweet smell out of the exhaust
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@Doubeleive your a godsend. I have enough experience here to be dangerous. I have smelt the exhaust, there is no odd smell, I also let idle in my garage for about 30 minutes and there was no water spot at end of exhaust. Oil looks like new, no slim on filler cap.
I'm so nervous about hydro locking though that I turned by hand after I filled it up last and crank turns w/o any issue at all.
I also drove to work just now. Was about 30 minutes of driving. Came back and put carboard back under engine bay.
Hopefully I can spot the pesky leak this time :) I've rebuilt a couple cooling systems for SBC and NEVER was this tricky. These little v6 motors are a bear with all the funky bypass elbows, I think coolant runs through intake, etc etc etc.
bigdog9191999
sw michigan
Being a 3800 I would guess lim gaskets. They don't usually eat head gaskets, although water pump is that bad to do either. I would say the upper intake could be cracked, but that should be aluminum that year.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I should put up a bet to see who can guess what it ends up being haha I don't know what it is about these v6 Chevy motors but the cooling systems are so damn temperamental. I've owned a couple 3100,at least this one 3800, and a 4300. They were all awesome little motors aside from coolant issues. Cannot say I had any issues other than idiot shop who worked on 4300 to change fluid though.
bigdog9191999
sw michigan
This is but a fraction of what I have had with these.
I had an 89 Bonneville sse with the 3800 in it. Loved that car. I never had a problem with the motor, except for a seized alternator, but the rest of the car was nickle and diming me to death. I wound up giving it away to someone.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@Tonyrodz For a while my dad drove the supercharged Bonneville...... OH WAS THAT CAR AWESOME! The little supercharged 3800 drivetrain is sooooo cool.
DANG! @bigdog9191999 that's a few!
I certainly like the engine architecture MUCH better than any of the imports. No belts, no overhead cams, or any of that BS to worry about.
SUCCESS, there is a leak! It's hard to see exactly where with the engine mounted sideways though. I may get some UV dye and dial in the location further... But I'm guessing the water pump? However, where's the weep on this thing... Isn't it behind the pulley? I'd suspect it would leak from the weep. The puddle is more towards backside of engine and above accessories.
Doesn't look like it's gonna be a fun job.
water pump leaks can be hard to find, probably have to use a flashlight and one of those angled telescoping mirrors from the autoparts store to find the exact spot
bigdog9191999
sw michigan
I have owned probably close to a dozen different ones over the years, and parted and scrapped at least twice that, and worked on others for them, so to say I am familiar is an understatement.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
One step closer, the heater core elbow directly above pump has water under it. I'm not sure if it's the elbow or the gasket.
Hopefully UV dye can sort it out. I recently replaced those elbows with aluminum *ahem* Dorman parts. I like that they are metal instead of plastic. However, Dorman doesn't exactly inspire confidence. I really cannot figure out how to easily distinguish leak from the elbow or leak from the intake gasket. They are so close together. I don't appear to be leaking anywhere else between the upper and lower intake, and there's no coolant getting in the combustion process (at least judging by exhaust).
I have also regularly maintained my coolant system. Changed fluids, etc. People seem to think aged DexCool coolant corrodes the gasket material. Right now though, I'm running mostly water because of this issue.
curbud
