3/5 and 285/45/22 or 305/40/22 on tbss reps?
Slammedchevy01
Someone had to run this setup...???
NBS 3/5 will a 285/45/22 work with a TBSS 22x9” +22 offset or can I go 305/40 like I had on 20x10 with +30 offset?
May replace the LTZ 20” and get bigger tires from Silverado
1992rs
OR
Couple thoughts
I’m sure plenty of people have put 305/40/22’s on 9” wheels over the years, but that is truly too wide of a tire. For one, the tire manufactures list a 10” as the minimum width for that tire. A pretty wifey accepted rule of thumb is, for optimal performance, you want to get your tread width (not section width) close to the width of the wheel. 305 tires look to all have 10.6-ish tread width. That translates to .8” of tread rolling over into the sidewall on each side. 15% of your tread will be used as your sidewall. Not optimal, not too mention the aesthetic would look very bulgy and bad
Now 305/40’s are shorter than 285/45’s (31.7 vs 32.1). The shorter tire will give you more drop, but simultaneously increasing fender gap. It’s not much, but the difference between the two sizes listed above would give you almost a 1/4” drop/lift AND fender gap increase/reduction. I’m not going to speak for what kind of aesthetic you want/should have, but IMO when you have too tall of a tire stuffed, it counters the work of lowering because the proportions get thrown off. You may have more fender gap but at least you’ll look lower with a shorter tire.
Some tire options for a 9” wide:
- 285/45 (32.1” OD & 9.7” tread width)
- 285/40 (31” OD & 9.9” tread width) realistically it’s too wide, but it’s a popular size with good options.
- 275/45 (31.7” OD & 9.4” tread width)
- 255/45 (31” OD & 8.9” tread width) only one tire option though and it’s $$$.
- 275/40 (30.7” OD & 9.4-9.7” tread width) idk why the tread width varies so much between manufactures on this size.
If it was my project with that drop, I’d run either 275/45/22 or 275/40/22. 275/45 is the best compromise of OD, tread width and tire options. 275/45 is roughly the same OD as the oem 275/55/20 that I assume is what’s on the ltz’s. Aesthetically, it won’t change your proportions you currently have. 275/40 would be a great choice if you can live with more fender gap and want to be low low. Thanks to the German super SUV’s, that size has a bunch of max performance summer and other high performance all-seasons if you drive hard and want serious grip. Alternatively, I’d try to get a 22x10 and run 285/40’s, but tbss’ are a great looking wheel so I get it lol
BADRIDES
Just run the 285-45-22 tires. So many more tire brand options for that size vs all those oddball sizes named in the previous post.
Here is NeverSatisfied Tahoe with a 285-45-22 and I think he was 4/6 drop. Message him about tire sizes. He's pretty smart on that stuff.
S
Slammedchevy01
Thanks guys!
Yea that’s funny I was searching for his post last night as I thought he had those 285/45 too damn it. Those reps 9” you know? Worse case I crank keys up a tad.
These 265s don’t give enough over hang for my liking on sidewall so 285 min [emoji16]
S
Slammedchevy01
Surprised how competitively priced the 285/45 is with 305/40. Thought those 285/45s would be marked up since oem size!
BADRIDES
Thanks guys!
yes 22x9
Dont know why anybody would say a 305/40/22 on a 22 x 9 wheel looks “bulgy” but here’s my ‘02 with them on 22x 9 reps +31mm offset with a 2/4 drop. I have run 26x 9’s with 305/30/26 tires with the same drop so you should be fine with either tire in question with your drop.
731BBADC-CA16-4915-951B-0AFBF2E6CA36.jpeg 56D2A302-51C3-41F0-89C9-39540C87A263.jpeg
S
Slammedchevy01
View attachment 249425 View attachment 249426
That’s not bad at all! My concern is yours are 22x9 with +31 but mine are 22x9 with +22.
You rub or close to rubbing??
BADRIDES
BADRIDES
Factory oem Traverse I want to say
Where did you come up with knowing that they would work? Can you get a closer up pic of the center cap on the wheel. I really like that cause most people have to run those chrome center caps on a satin wheel.
S
Slammedchevy01
Don’t mind the Philthy wheels lol
I’ll text my buddy to confirm what they are off but he figured it out. They look so much better than chrome, just took those off today .
S
Slammedchevy01
285/45 seems big but I guess if I can run a 295/35/24 I can run a 285/45/22
Hodmjstone
