21+ IRS SAG issues when towing product design (looking for someone in Michigan)
dbphillips
Met a guy with a Silverado and he swore there was an extended bump stop solution for the SUVs, but no, I didn't find it.
Polo08816
In my case, the 650lb tongue w/WDH pulls my 2021 Yukon rear down 1 inch and front raises 1/2 inch. My model doesn't have air bags. This is perfectly stable towing and no complaints but I'm just wondering.....
IF I add the 35% stronger rear springs and let's say the rear only goes down 1/2 inch instead of 1 inch - will the front still go up 1/2 inch? or less? A recent comment suggests the front will still go up the 1/2 inch and this is consistent with some youtubes I saw.
Bottom line, for me, just wondering if adding stronger rear springs would have significant benefit. How about down the road and I have an 800lb tongue weight trailer (with WDH) instead of the current 650lb? What if we load the full 1400lb worth of cargo (tonque + us = room for ~450lbs of junk)?
Are you referring to this?
FYSA, it's advertised as "+35% carrying capacity over OEM stock springs" but that doesn't mean the spring rate is 35% higher.
tagexpcom
Thank you for the comment. It's nearing a year of ownership and 6000 miles of towing and only 1" sag in the rear (hardly noticeable) and the rig is operating/towing smoothly - so I think I'm just 'over noodling'!!
dbphillips
Watch your tires like a hawk - the dealer won't.
Cdisharoon84
