- Joined
- Aug 2, 2018
- Posts
- 6,592
- Reaction score
- 8,657
These quick disconnect connectors may be helpful to you to quickly remove the speaker box.
Orion Motor Tech Wire Connector 4 Pack, 175A Wire Harness Plug Kit for 2 to 4 Gauge Cables, 12V to 36V Battery Quick Connect Disconnect Set for Car Bike ATV Winches Lifts Motors More, Set of 4, Gray
I have a second battery in the truck that I use as a spare, and that is how I have it connected into the system, so that I can easily connect/disconnect it at any time.Thank you sir!
Might need to add similar for the XS Power battery as it doesn't look like I can hide it anywhere due to size.
Care to share your setup pics? Not going to be a fan of having the battery in sight, so I think i'll set the sub box on a flat piece of wood and make a open box to drop it in for "quick" removal.I have a second battery in the truck that I use as a spare, and that is how I have it connected into the system, so that I can easily connect/disconnect it at any time.
WELL..... not ideal in my opinion, they make fuse tap adapters to connect a wire properly, basicaly it's a fuse holder with a lead soldered on which is much cleanerView attachment 424401
So based on this, looks to be the proper location for the remote wire into the LC2i Pro. Already have a remote jump for my cameras...adding in another remote jumper be ok? Will find a more "proper" way to do it vs wrapping around legs and pushing in .
Was looking at the D4S amps, picking up an Orion XTR 2500.1 local for a good deal later today; fits perfectly under the 3rd row seat w/good air flow around it....as I always have the AC turned on for the feet as well as vents. Was running an X15 with SCV-3000D in my F250, but that already had 2 batteries and didnt drop below 11.5 if I recall. But I will be needing a secondary in the AT4.
So running 2 remotes from that fuse would not be an issue? I actually have some of those circuit adapter holders here....apparently got lazy when I was doing my camera install lol.WELL..... not ideal in my opinion, they make fuse tap adapters to connect a wire properly, basicaly it's a fuse holder with a lead soldered on which is much cleaner
tons of different ones on amazon, not sure what size that is in your photo, gm has decided to use like 5 different kinds now
no it should be fine, you can piggyback off anything else already on a trigger, all it is looking for is a small voltage signal there is no amp draw per sey.So running 2 remotes from that fuse would not be an issue? I actually have some of those circuit adapter holders here....apparently got lazy when I was doing my camera install lol.
Perfect fit. Now to mock up a panel to mount it to with short rubber stand offs for shock damper and also air flow under the amp.
Those yinlong cell swaps are around the same price as adding a secondary battery and wiring for it. You’ll have better voltage with the lithium for your moneyView attachment 424401
I’m pretty sure you do away with the battery if I’m not mistaken I’d have to check with my two buddy’s I haven’t actually done this setup yet but a couple of my bass head buddy’s have and had great results. Plus the lithium is supposed to last 10years or so supposedly over a normal battery which might get what 3 years? Before needing to be replacedWith Buss bars and balancer: https://bigjeffaudio.com/collection...ium-titanate-oxide-lto?variant=43785197093112
How to Build:
I can laser cut out my own acrylic box for protection.
So once ready to drop into the vehicle, run a + and - from the battery (inline fuses needed?) straight to the lithium box and then straight to the amp?
