2022 Suburban Premier Tires/Wheel Upgrade
santiagovm
Long Island, NY
Looking to upgrade tires/wheels on a Suburban 2022 Premier. The car came with 275/60R20 tires and 9Jx20 ET28 rims. The vehicle also has Magnetic Ride Control.
My objective is to make the car look more off-road without making significant changes and keep a balance between appearance and comfort.
Looking for a style similar to the one here. Aggressive tires with a small wheel (315/70R17).
Some questions:
1. Are the 17" wheels too small to fit the brake components? If so, what is the smallest rim I could use?
2. To fit 315/70R17 tires, I assume that leveling or lift is required. Is the magnetic ride control affected by this?
Any suggestions on leveling/lifting kits?
3. What is the biggest tire that will safely fit without leveling/lifting?
Thanks in advance for any information.
olyelr
Elk Rapids, MI
Do you have the air suspension?
A lift or level kit will require some different links for the magnaride to work.
Fitting a 35x12.5 tire in there will certainly require at least a small lift/level, and most likely some trimming as well. I believe the guy in that video you posted said they did some trimming in the front wheel wells for clearance (havnt watched it in a while). I just put 305/45/22 tires (roughly 33x12) on the wifes 100% stock ‘22 tahoe high country (no air suspension) and they fit just fine, no rubbing anywhere.
I know big gnarly mud tires always check the appearance box, but often not so much the comfort box.
I doubt a normal offset 17” wheel would fit over the brakes, but i honestly dont know. I would guess a minimum of 18” is needed.
Blueinterceptor
If you want a little change but an improvement in utility and looks for off road appearance but not a loss in comfort.
keep the standard tire size and put Michelin a/t2 tires on her.
OR if they still make them Goodyear silent armor tires.
Either will give you an off road capable appearance and utility in use. And a smooth quiet ride
S
santiagovm
Long Island, NY
Olyelr,
Thanks for the info, very helpful. No, I don't have the Air Suspension, only the Magnetic Ride Control.
The 305/45/22 could be an option for me. Will need to find the equivalent for 18" wheels. I am starting to lean towards a setup that does not require leveling/lifting. Also interested on 275/70/18.
olyelr
Elk Rapids, MI
Olyelr,
The 275/70/18 is basically the equivalent of the factory 275/60/20, so they should fit just fine with no issue.
S
santiagovm
Long Island, NY
This is an update on my original post. I upgraded the tires/wheels.
The information on this site was fundamental to my project. Thank you.
Below is a side view picture of the before and after
Tire/Wheel Specifications​
Before:
  • 275/60/20 (33x10.8) OEM Tires Continental Cross Contact LX
  • 9Jx20 ET28 OEM Chevrolet rims
After:
  • 305/70/17 (33.8x12) Nitto Ridge Grappler (217080)
  • 9Jx17 ET1 Fuel Tech Matte Gun Metal (D67217908450)
Leveling Kit​
I also had a Rough Country leveling kit. My car has Magnetic Ride Control, and I have had no problems. The installer indicated it added 1.5" of height. I did not get the details of the part that was used. But here is a picture after installation. It looks similar to the one here.
Tire Rubbing​
This setup has a little bit of rubbing at full turn. I am deciding between living with it or doing some trimming.
The left image below is the original tire at full turn. Notice the 1/4" gap. The image in the middle is the new tire touching the fender cover. The image on the right is me pushing my finger between the new tire and the fender cover.
The image below shows the driver's side and the passenger's side. Notice that the tire is touching a metal piece behind the cloth coverage on the passenger side.
more info and pictures in the next post...
S
santiagovm
Long Island, NY
resuming from the previous post...
Brake Caliper with 17" Wheel​
The brakes fit with the 17 wheels. The installer indicated that the new rim needed to be offset +1 instead of the original +28 to ensure the caliper fit.
More Pictures​
Reference​
  • Thread: Lifted/Leveled 2021 - Postem Up (link)
  • Thread: 2021 Leveling/Larger tires (link)
  • Post: Aftermarket wheels #1 (link)
  • Post: Aftermarket wheels #2 (link)
  • Post: Aftermarket wheels #3 (link)
  • Post: Aftermarket wheels #4 (link)
  • Thread: 305/45/22 will fit nicely! (link)
  • Tool: Wheel-Size.com (link)
  • Tool: Wheel Visualizer (link)
  • Tool: Wheel Offset Calculator (link)
DenaliCountry
More Pictures​
Reference​
Looks great! I am starting to think the direction I am starting to go would fit without rubbing. Thinking about replacing the stock 22's on my denali (Has air ride) with 20x9 rims +1 offset with a 295/55/20 tire. Is it rubbing after the level? Did you test fit without a leveling kit to see how they fit in stock ride height?
S
santiagovm
Long Island, NY
Thanks. Yes, there is rubbing after the level. No, I did not test the fit without the leveling kit.
JerseySUP
That "wheel offset visualizer" is fantastic. Never saw that before!
a1parrothead
