2018 Escalade - PPV Caliper Upgrade - help needed
atr87
Hi all,
I am looking to do the OEM PPV 6 piston caliper upgrade (front) BBK on my 2018 Escalade, and while I've found a really helpful write up (https://www.tahoeyukonforum.com/thr...es-on-all-4-corners-of-my-19-escalade.155356/), I am still unable to confirm which SS brake lines work with this setup and which banjo bolts can be purchased that won't require modification to bolt up properly.
anyone know off hand?
appreciate the insight!
jyi786
I think I used Stoptech.
Did I not put this in my post? I might have forgotten.
Yes, Stoptech is what I used as well. Believe it or not, I had left over SS lines from my 2012 Yukon Denali, and they fit on our trucks (2015-2020) as well. The part number is StopTech® 950.66002.
Word of advice: DO NOT use the banjo bolts that come with the Stoptech lines though, they have a completely different torque rating than the stock OEM banjo bolts.
I found out the hard way when I was tightening and I felt it semi-collapse in the bore; luckily I reversed it out before any more damage could be done.
Per your question: which banjo bolts do you use? Use the GM ones in my other post and you should be golden. Yes, you can use it with these SS lines.
A
atr87
Thank you for the confirmation man! I probably missed it in your thread.
Ordering the front setup today, can't wait to get these on my 2018...!!
jaxscuby
Jacksonville, FL
ordered mine from summit racing, goodrich stainless steel braid lines.
2 for the front, 2 for the rears & it came with 2 for the ones right above the rear end.
TexasTaz
