Hi
About a 2017 gmc Yukon, the front differential is completely damage inside, the pinion and bearings are melt and I proceeded to remove it in order to be able to use the car because of economic situation I can't afford to repair or buy new, it's my girlfriend car and I removed the CV joints and the shaft bar too but my concern is if there is any safety issue by removing the CV joint spindle frOm the wheels if the center nut supports anything other than that or is safe to drive without it. Thanks so much in advance for the support
