Campie
- Joined
- May 23, 2025
- Posts
- 140
- Reaction score
- 65
Thanks! I’ll snap some pix later and share. We love the car but as with any used vehicle there are always things that need attention!
depending on your year they changed the maf design from a screened unit to just a module that mounts in the intake housing in a rectangular slot with 2 bolts.Thanks! I’ll snap some pix later and share. We love the car but as with any used vehicle there are always things that need attention!
Check your brake booster for any leaks. If you have Torque or similiar, what does the vacuum show at idle and when the brake pedal is pressed?
Hi, thanks for the details. Ours is the traditional MAF, not the rectangular model and it does not have a screen, although it is labeled AC Delco. Pretty sure it’s never been replaced and there was a huge difference in the fuel consumption when I sprayed it with the cleaner so guessing I’ll replace it and mark that off the list!depending on your year they changed the maf design from a screened unit to just a module that mounts in the intake housing in a rectangular slot with 2 bolts.
should be extremely easy to tell the difference. anything after 2008/2009 is just a rectangular module, being it is a 6.2l it may already have the rectangular design but can't say for sure,
pictures would tell a lot.....
looks like there is also option to have a screen or no screen and has a maf module that just clips in with a o ring seal
***this is why you stay away from new design years lol
Sorry, you are way past my limited knowledge of mechanics. The carpool is great and we have had no problems at all except the two times. Both times it was low 90s, we were on the highway, down to a quarter tank and pulled off on an exit to get gas. The car stuttered at the traffic light at the exit ramp, but didn’t stall until we slowed down to turn into the gas station. Both times, after 10 or 15 minutes, it started back up again and was fine. Not sure if there were any codes thrown. I have a scanner, but I am not sure how to use it yet. I’ll get you an update! Thanks!Check your brake booster for any leaks. If you have Torque or similiar, what does the vacuum show at idle and when the brake pedal is pressed?
I've seen more than a couple brake boosters over the years that only leak once the brake pedal is pushed.... Would definitely cause stalling when coming to a stop...
Vacuum testing the booster will tell you
not sure I can figure out how to do that, but I will think on it and see what I can come up with!Check your brake booster for any leaks. If you have Torque or similiar, what does the vacuum show at idle and when the brake pedal is pressed?
Yes, I have certainly seen that suggested and would be happy to give that a try. Unfortunately, I’m at a loss as to how to do that. I know what the fuel rail is, and I’m guessing the part that needs wrapped is behind the engine where it goes down And passed the transmission. Correct?This is a very common issue with 2007 6.2s. I don't know what's physically different between them and later years, don't think there is any. However, several people have seemingly solved the issue by wrapping the fuel line to keep it from getting too hot for vapor-lock.
My memory is not so good, the answers are 4-8 years back on the pages of this forum.
Yes, we had that problem also. A part of the clamp on the negative was missing. Once we fix that, it was good! This stalling/no start is different though.@Campie I can't think of anything that would cause it to not start once it's hot but when I experienced cranking without ignition was after a rebuild, I didn't have the negative battery cable tightened all the way down to the front of the passenger side head. After I tightened that it fired right up.
OK, i have the part and I have located the old one in the vehicle, but I can’t figure out how to get it off of the metal clip. Can you help?Sounds to me like your vapor Purge solenoid. It literally takes just a couple minutes to change it. If it's stuck open, it's getting flooded with fuel vapors from the carbon canister. Pretty common issue.
Below is a picture of it and the part number. You'll see it on the driver side of your intake manifold alongside the fuel rail.
Actually, we did try holding the gas pedal down and that didn’t fix it. The only thing that fixed it was 10 or 15 minutes with short cranking every 3 to 5 minutes.Next time it's a crank-no-start after a hot soak, try using the "clear flood" method. Push and hold the accelerator all the way to the floor, and that shuts off the injectors. While doing that, if it starts after a short crank, an injector is leaking or the purge solenoid (as described by @rdezs) is staying open, or something else is causing excess fuel in the intake.
For test purposes the purge solenoid should be closed (no air getting through it) with no voltage applied -- in the raw -- but open with 12v applied. Polarity doesn't matter for testing.
Never mind, got it! Unfortunately, we won’t know whether it works until we are pulling the camper and it’s 90° and we need to get gas. But at least I know it’s done now, thanks!OK, i have the part and I have located the old one in the vehicle, but I can’t figure out how to get it off of the metal clip. Can you help?
