dat_boy_greedo
- Joined
- Jun 16, 2026
- Posts
- 7
- Reaction score
- 7
Hey Guys!
I’m new here so apologizes if this has been answered previously or if this is some obvious fix.
So I just picked up this 04 Tahoe for almost dirt cheap knowing it had some issues but its pretty clean for a Michigan car and I’ve always wanted one of these so I said screw it, its probably something simple and ill have it fixed in no time.
Fast forward a couple months the problems still persist and I’m at a loss.
So currently the truck is still showing lean on both banks with a random misfire. It does have a CAT code as well as both of the wheel speed sensors codes so I know those need to be replaced. CEL, ABS, and TC lights are on. The truck runs fine at idle and just driving it normal no problems show up until I really get on the gas, once it gets over 3200-3400 rpm the truck fall on its nose like it has no power and the random misfire starts. Intake hoses look good. I haven’t been able to detect any vacuum leaks or anything like that. Does have a slight exhaust leak on the driver side. I have not come across anything to this point that to my knowledge would cause a lean condition on both banks along with the random misfire.
Seeing as it was lean on both banks and it was having fuel pump issues my first guess was a weak fuel pump. I replaced the old original fuel pump with a new Delphi unit. Made sure the wiring looked good, lines looked good, and buttoned everything up. Problem still persisted. I cleaned the MAF, nothing changed. Unplugged the MAF to troubleshoot further, nothing changed. Replaced the MAF on a whim, this is where I got my first change in performance for a little bit. It seemed like it had more power. I did a couple pulls on the freeway to get the rpms up and there wasn’t a misfire or anything for a good 30 minutes of messing around (doing pulls from 60 to 90) truck seemed to have more power and then it started to act up but in a different way then normal. Where it would start random misfiring before (around 3300-3400 rpm) it just started falling completely on its face and where it used to feel down on power it felt like there was no power and would actively lose mph until I let off the throttle but I didn’t get the random misfire sound or anything, almost like the power was just disengaged from the driveline. Again driving normal it would act fine but if I got on it then it would start to act up. This happened for about 5-10 minutes, basically until I pulled up to work.
I am at a loss because honestly I thought that this would be a simple fix. It turns out that these trucks might be a little more complicated than I first thought lol and I work so dang much that I just don’t have a ton of time to spend trying to trace this down.
To anyone who answers I really appreciate you taking the time to try to help me out.
