builds4christ
- Joined
- May 14, 2024
- Posts
- 81
- Reaction score
- 57
I get what you're saying.
I wouldn't mind venting it to atmosphere, but was honestly unsure about which line to disconnect.
The truck had a lean problem initially, until I discovered a huge vacuum leak at the MAP. Then it decided it would go rich. So a rich condition is my most recent battle.
The PCM was modified not to purge, as far as I can tell. You may be on to something though. I wonder if it is venting properly. Even if it's not the reason for my current issue, it's still something I should address.
Isn't there some way to vent the tank to atmosphere, but THROUGH the canister to prevent the smell?
