2003 Yukon SLT flex fuel 5.3L whats brand would you use? cam, oil pump, lifters, timing chain
Summajet
I had another post on misfire on #2 and I removed the passenger side head and the one of the lifters (towards front) appears to have turned 90 degrees and has ruined the lifter and the cam lobe.
I have drained oil last night and waiting for it to filter through the towel and look for metal particles. I did cut the oil filter open and I did have some small metal particles from the lifter in the paper pleats of the filter. I will look at the drain plug tonight and also the towel to look for metal particles. I have not pulled the oil pan yet to look at the screen or pan. Looking at the bottom of the valve of the bad lifter it does have some pitting and I am assuming that part of the metal exited through the exhaust port?
I have not removed the Driver side head yet. Looking from inside the passenger side head other than the cam lobe damaged on the #2 cylinder it looks normal wear. I was planning on using a boroscope and look inside the camshaft housing for damage.
Has anyone ever had a lifter collapse or turn like mine and have metal particles in the filter and if so did you have to do a complete rebuild?
I don't want to do all the work and it have ruined the crank bearing and in 6 months the motor fails. I know it is a gamble anytime metal particles are found in the oil filter.
Prior to removing head it had good oil pressure. Just ticking noise/ felt like sitting on an uneven load in the washing machine while sitting in the drivers seat while idling.
It has 235,000 miles and I two a trailer and a boat at times. I'm not looking to increase performance, just replace parts and keep stock.
Here is what I pondering,
1. replace all 16 lifters
2. replace camshaft with Oem or stock
3. replace oil pump and strainer tube assembly
4. replace timing chain
What brand of parts do you prefer????
Camshaft, SKP SKES1067??, MELLING MC1383 {#12560967, 8125609670??
timing chain????
ACDELCO 12646386 GM Original Equipment
FitsGas
orFlex Fuel
GM Lifters?????
ACDELCO HL124 {#17122490} GM Original Equipment
FitsFLEX Fuel; HYD, ROLLER, NON-ACTIVE FUEL MANAGEMENT LIFTER
orGAS; HYD, ROLLER, NON-ACTIVE FUEL MANAGEMENT LIFTER
Oil Pump ????
MELLING M295HV324S
Includes M295HV Oil Pump And 324S Oil Pickup Tube Assembly; High Volume Oil Pump; 18% Additional Volume over Stock Oil Pump; Recommended For High Mileage Engines
Thanks!
SnowDrifter
Washington. The desert side not the Starbucks side
No input on the rest of the parts list. But I put a melling m295hv on my rig. Quite happy with it, performs as intended. It's both high volume and includes a high pressure spring. Just don't cheap out on oil filters if you go that route. the thing puts out about 110psi at redline on a hot engine. I'd be worried about a cheaper filter shredding itself internally or blowing off. I use the longer filters. Fram PH 3675 or amsoil eao64. Cross reference if you want something else
S
Summajet
I had a productive weekend. I got everything removed except for dropping the oil pan.
I got the can out. In again to the #2 cylinder lifter the top of the #3 lifter fell out on top.
So far good.
So far good.
Make sure you replace the lifter guides, that is SOP when replacing lifters. Did you pull the oil pan to clean it out? How about the camshaft bearings? Did you pick a camshaft yet? I was going to suggest the L33s, camshaft (12583623), a little bit larger for a little more horsepower and torque while towing. That Melling cam you picked out in the list up there is for a 6.0 I think.
S
Summajet
I have to drop the 4wd reach to get clearance to drop oil pan.
Can shaft bearings looks good.
Definitely replacing the lifter guide trays, push rods, and rocker arms.
Yep, at least take out bolts some and let it hang. You don't want to leave any bits of metal in there after all that work.
S
Summajet
I talked to master mechanic and he said he had an 07 5.3 and lifter went bad. He flushed the valley pan with diesel with the oil pan removed to make sure he got all the metal out of that more
SnowDrifter
I seem to recall there being better/upgraded lifter trays. I don't know anything about them, but hopefully that will get the discussion started.
If you replace the cam bearings. GET. THEM. LINE. BORED. These motors are apt to spin the things otherwise. Block warps a wee bit with time. Honestly same could be said for line boring the main bearings but I don't often hear of too many issues with that. I'll leave that one up to OP for the cost/quality/benefit analysis
S
Summajet
I got the oil pan removed and no metal in the pan. Took mini vacation so not much progress to report back on.
