16 Tahoe Grease fittings.
LT1ZOB
Those who DIY their maintenance, how often should I be greasing these suspension fittings? I use Lucas products on my trailer wheels. Do you guys have specific grease recommendations? Thanks
What grease fittings? I bought a fancy lucas grease gun and the red-n-tacky and crawled underneath expecting to go to town and... 2 fittings! 2 lousy fittings on the tie rod ends, everything else is sealed. Of course I can pull the driveshafts and make sure the yokes have synthetic grease on them but that is it!
So Bob, come on over and grease your tie rods, if I don't share it, that tube will probably outlast me!
Bob2C
Northern VA
yeah seriously. Why bother with the 2. I was expecting a few more. Like you sad, grease will outlast us. Lol
Bob2C
Northern VA
I have been doing them every other oil change. My OIC is 3 to 3500 miles
2006Tahoe2WD
Silicon Valley
Do the zerk fittings on my 2006 have a "standard" thread? I think one of my fittings is clogged and needs to be replaced.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I personally never saw a difference in zerk threads for the GM products but am sure they may well be a difference.
2006Tahoe2WD
Silicon Valley
I'm going to guess the thread is 1/8" tapered. I could pull one and find out. I also got remined that the fitting on the gun can be tightened and loosened to get the connection and have it not slip off when pumping in the grease.
2006Tahoe2WD
Silicon Valley
I got a couple of different types (straight and 45 degree) fittings at a local parts store. We have one old style car parts store left. I took a fitting I removed from the Tahoe to check that I got the correct thread. I installed the new fitting and it worked fine. Now I need to remove the fitting on top of the idler arm - it seems to be plugged up. I also got a new flex hose with a coupler at the end to put on my grease gun. I also got a 45 degree fitting and added that. We'll see how it all works.
Drewphil
