09 Tahoe Oil Consumption issue solved
Bowtiebug
I have made a few post about my 2009 Tahoe 5.3l using excessive amounts of oil along with reading several others with the same issue .
My Tahoe was using 3/4 to 1 quart every 800-1000 miles or regular everyday driving , So I recently had time to go speak with a old friend of mine that is a GM Master tech with 35 years Plus under his belt .
I explained the issue to him about oil consumption and he ask a few questions like.
1. does it misfire or get a check engine light ? my response was no , he says that pretty much rules out a piston or ring issue .
His next question was lets pull the Air hose off throttle body and look inside the intake , To my surprise it was soaked with oil .
He then proceeded to ask if I updated the valve cover on Drivers side with new style PVC system, my response was no and he said try it first it fixes 99% of oil consumption issues as the old style cover has the PVC port directly above a push rod and rocker arm and gets a constant spray of oil .
So we went to the parts department and I purchased the new style valve price with tax $92.33 part # 12642655 ( see photo's ) .
I went home and changed it out , which took about 15 minutes with my 1/4" air ratchet and a 10mm deep socket and swivel .
a few days later we took a 1075 mile trip and when we got home I checked the oil and to my surprise it was still slightly over the full mark were I placed it prior to the trip , since then I have made several other trips totaling around 2600-2700 miles and my oil is still full , my oil consumption has stopped completely with the new Valve Cover , I'm very pleased :roflbow:
I also use a Range module to prevent 4 cylinder mode , but it did nothing for oil consumption in my case as it wasn't due to pistons or rings , but I do love the Range module which gives me 2-3 mpg better fuel mileage and smoother drivability .
NathanJax
Vacation Nathan
Jax, Fl
good info!
Texastoad
Galveston Texas
Good info...I have the same year model and engine...wonder if I should just go ahead and do this change....I will watch level closely...have only had truck a month
B
Bowtiebug
I would at least pull the cover and see if it's been changed or not , the new cover comes with the gaskets and new bolts , very easy to change , there's 1 main coil connector , 5 bolts that hold coil pack bracket on and 4 bolts in cover .
Goodinblack
I Like Tacos
Dirty South
Great post.
People should realize one thing However....
That part is is YEAR SPECIFIC.
Years have different parts number for the cover.
GM P/N 12570427 for 2007 - *2008
GM P/N 12642655 for 2009 - *2011.
B
Bowtiebug
Great info ^^ goodinblack , my suggestion would be to have the parts department verify your vin number for proper parts ID and figment .
ezdaar
Chat Troll
Redneck central, Aka Houston
hmm, just had a thought. if moving the PCV from above t a pushrod solved it.
And theres probably no covers like that for 99-07.5,
Im thinking move the PCV on older VC's by filling or covering the OEM PCV hole and welding on a bung in new location..
Wonder if they would sell...?
jstutz101
Kankakee, Il
I suspect the oil going back into the intake is whats jazzing up the throttle bodies requiring them to be cleaned or replace so often. Good info!! Thanks!
HoS
Very interesting information.
Thanks for sharing.
jz57
How can I tell the current exist driver-side valve cover is an old or new version without removing it?
B
Bowtiebug
As far as I know you can't , they look identical from outside , the only noticeable difference is on inside .
My local dealer ran a Vin history for me to see if a dealer had updated it , you might try that .
Damien1990
Great post.
So I can buy P/N 12642655 and put it on my 07 Engine?
B
Bowtiebug
No that part number is 09 up , parts department can check vin and get you correct part for your engine
Addicted
Warren PA
Great info. I dug through the receipts for the 07 I bought last fall. Luckily it has been updated, and they also replaced a deflector in the oil pan. ??
mfinta
