live data dump. what do YOU see?
commercialfshrmn
it might be to either the ride height sensor or the shock or abs sensor, I don't recognize the plug off hand check all around the general area
interesting.i definitely will here directly. here is nothe plce it could go, just by sight and feel
commercialfshrmn
well.....i might have found my vacuum leak, lol. the airbox doesn't have the rubber grommets & wasn't in in the holes properly. map sensor, & more oem stuff & run live data again, later. will take more videos.
SpareParts
North Idaho
Before the MAS should not affect running. Air leaks after the MAS make problems.
Check the PVC hose for a crack. DR side valve cover by the firewall.
Make sure your intake tube is tight and has no cracks or holes underneath.
If original intake gaskets, they could be leaking underneath
Pass side valve cover in the front is a breather pipe. Make sure that hose is good.
Make sure your oil filler tube is sealed as well as the cap.
Look over the intake and make sure there are no open holes.
CRN_25
