07 Suburban Missing Key Features on DIC
_GMAN_
My LT is missing some key features on the DIC. I don't have the trip meter, but not the fuel range, Avg Economy, Fuel Used, Speedometer, Trip Timer, Trans Temp, Instant Econ V8. I am missing all of these features. Can I add them by getting the DIC controls from a higher trim model?
mikez71
As far as know, you can plug in the buttons and will all work.
I am not clear on what features are displayed and what features are missing. Maybe, I'm not reading your post correctly.
_GMAN_
_GMAN_
I have all the buttons, I just don’t get those features. I’m wondering if I need to get the module from an LTZ or a Denali? Or is it my instrument cluster that is limited?
The features I listed does not show on the display when I toggle through.
mikez71
My Z71 is an LT too, I don't think it has to do with that..
And I doubt its the buttons.. maybe something in the cluster changed at some point?
Since yours is an early model...
Might be worth a shot to unplug your battery, in case the cluster senses the buttons on powerup? idk..
You did try all the buttons? Some options are on the second button down..
_GMAN_
_GMAN_
I learned that the 4 button module is unique to the specific model. The one I had left out all the key features I mentioned. I got the module from a Yukon Denali and I got all the missing features. The junk yard is full of of these. If you are looking to upgrade the part number on top is the LT and the part number on the bottom is the Yukon Denali
mikez71
Wow! Nice detective work! That's the first I've heard about different buttons.
Odd that an LT Tahoe can be better optioned than a LT Yukon..
Maybe they standardized the upgrade at some date?
OR, your first switch was somehow faulty? (not seeing how...)
I only say that because the diagrams are the same for '07&'08 chevy/gmc & cadillac...
And the info button looks like a straight switch...
Moderator
People's Republic of Colorado
Based on the orientation of the picture, would you clarify which one on the left, and which on the right (instead of top and bottom)?
_GMAN_
_GMAN_
The part number that starts with the 718 is the DIC module that is from my LT Suburban.
_GMAN_
_GMAN_
GMC's has always been a slight upgrade from the Chevrolet version. Since the Yukon's used SLE, SLT, and Denali for their trims. SLT is equivalent to an LTZ with the options. My Suburban was a 2LT option. Just one step above base model. Not many options. It's nice to know all these parts are interchangeable.
_GMAN_
_GMAN_
All Driver Information Center (DIC) features were not available on all GMT900 (2007–2014) trim levels from the factory. While the underlying electronics capability was present in most vehicles, GM restricted access to certain features based on the trim, primarily through the inclusion or exclusion of the steering wheel control buttons. My Suburban was a base model with some added upgrades like leather seats.
Key Differences and Limitations
  • Base/Work Truck (WT) & LS/SLE: These trims often came with only the basic "reset stem" on the instrument cluster, which limited the DIC display to basic trip, odometer, and limited warning messages.
  • LT/LTZ/SLT/Denali: Higher trims typically included the full DIC steering wheel controls, allowing access to advanced features such as tire pressure monitoring (TPMS) display, oil life customization, engine hours, and personalized vehicle settings (e.g., exit lighting).
  • The "Plug-and-Play" Factor: In many cases, the wiring harness for the full DIC controls is present behind the dashboard, even on base models that didn't come with the controls from the factory. Many owners upgraded their base trucks by simply installing the higher-trim switch panel, which then activated the "hidden" features.
  • Common DIC Features Across the Platform
    • Trip odometer
    • Fuel range
    • Average fuel economy
    • Oil life remaining
    • Engine hours
    • Individual tire pressures
    • Trailer brake controller information
    Essentially, while the hardware capability was nearly universal, the enabled features varied by trim, with higher trims having more advanced, accessible functionality.
j_jerry79
