LSCALADE
- Joined
- May 6, 2025
- Posts
- 227
- Reaction score
- 603
Attached are my 2 files (BASE) and Tuned:
Things I have done.
Engine side:
1. Enable the flex fuel sensor.
2. Ethanol content min and max values adjusted to 0-80%.
3. Adjusted Stoick table so it reads from 14.6 to 9.
Transmission side:
I have adjusted the shift speeds and scheduling.
TCC apply speeds adjusted so they are 1mph after a gear change.
Pressure bumped from 26 to 31psi.
SLip reduced by 50%.
DOD Disabled.
I have been self learning HP tuners for exactly 1 year now, and I have figured out quite a few things and will help anyone who has any questions on the things I have done so far.
As far as tuning spark tables and other things, I am a newbie, so you've got to ask the professionals.
Feel free to compare my stock and modified V3 file to see what changes I have made. Note that all these changes were done slowly, one at a time, until I saw results.
Next on the list is AEM wide band oxygen sensor integration into the ECU With a pass through OBD plug for the gauge.
Things I have done.
Engine side:
Transmission side:
DOD Disabled.
