Emergency lighting
GranPrix
For the vehicle in the bottom/right photo (Tahoe with blues in the rear) - what did you use behind the hatch glass, both for lighting units and, more importantly, for mounts! Thanks!
- Scott
Those are Avengers and they're mounted with the factory Whelen brackets.
GeroniMoe
South Shore, MA
Gotcha - I've been looking for bolt-on (or nearly so) behind-the-glass mounts for my 2020 'hoe, with minimal luck. I've found references to a few, but very few sources that have them...
(and what about the upper light-stick?)
Thanks for the info!
GranPrix
That's the RST also with Whelen brackets that bolt up to the hatch.
rick3645
