Air filter restriction indicator
GMT800 2005 Tahoe Z71
Navy Supporting Member
I want to get a new air filter restriction indicator but cannot be found at RA unless I am wrong. I went to GM parts and got the AC Delco part #15073765 but no luck with that at RA or Amazon.
I thought this was it but when I look at it at Amazon it says it does not fit my 2002 Tahoe. I can see a rubber grommet mounted in the filter housing and looks like this plugs right in but was told it is not right.
I thought I saw a crack in it but on closer inspection, no crack. False alarm.
I always figure that a device like that is there for a reason and I try to use it but I also look at the filter to be sure it is needed.
I don't wait till I hit a brake pad squealer, I look at them. I check belts and hoses without waiting for a belt to fly off or a hose to burst.
Many items are there to help avoid a breakdown. I get it though.
JonnyTahoe
Minneapolis
Those ''Squealers" are so nice. after I start to hear them I know I still have many more miles left on the remaining pads. I like to get them wore down to about the thickness of a dime or when the grinding starts.
To each there own then. I don't want to hear a squeal noise, ever! Grinding brakes are unsafe. The most important system on any vehicle is the brakes, period.
JonnyTahoe
Minneapolis
Just kidding Ron. I just replaced a rear caliper last week and installing new Napa premium pads today. I will post a few pics.
I kind of thought you were kidding but I just wanted to poke the stick to see what happened. Your no damn fun. :nolol:
ks03
Fool Excess Member
when I was working at a dealership I’d see the indicators moved on duramaxs when they were due, but only a few gassers ever, but I think they’re usually replaced before they’re bad enough to impact performance or move the indicator. Kept off a gravel road, a lot don’t look that bad at 100k. Of the gas engine ones with the indicator moved, one had the filter wet and apparently it dries into a brick, looked pretty good until you touched it, another was a new no name cheap filter, apparently just junk out of the box. Seemed like the gas engine ones could be very heavily covered without budging the indicator.
new2yukon
My indicator mjst be broken. Never moves from "bad" even after a new filter, which I install every 12000 miles.
Had oil analysis done on my car before and after air filter replaced. Huge diff. The old one didnt look bad but the lab found issues that they said was prob dirty air filter. Next sample returned to normal spec.
We can't assume a filter looking good is good, and that makes me wonder any value in the indicators. My car filter didnt look bad. But it was.
MeanSlickCaddi
