My Non Recalled 2024 Yukon L87 Engine Is Failing - Full Of Metal @ 17k Miles
jfoj
Engine lasted 17,732 miles/423 engine hours. Engine still starts and drives fine, no noises, no vibration, no error codes, but it is not IF it fails, but WHEN it fails at this point. Luckily for me and my family I did not become another L87 roadside statistic.
2024 Yukon Denali Build 08/24 with Engine Build Date July 15, 2024, this vehicle was not part of the original L87 engine recall, matter of fact this vehicle has never had any recalls. This engine was built at least 2 weeks after GM claimed they corrected all the crankshaft machining and journal finish problems and cleaned out any machining debris. This should have been a "GOOD" engine.
Purchased in Oct 2024 new with 8 miles, 3 of these miles were put on during test drive.
I am the only driver and vehicle usage is about 85-90% highway, no towing, no excessive loads, just a family hauler.
All service and maintenance performed by me. Vehicle has never been to the dealer or any shop other than for state inspections.
Range DFM and Auto Stop/Start module installed at 275 miles.
6 oil and filter changes in 17,732 miles. 2 FilterMags installed at 300 miles and Magnetic oil drain plug installed at 544 miles during first oil change.
Oil changed at the follow mileage: 544, 3484, 5923, 10093, 13801 and final change at 17,732 miles.
0W20 removed at first oil change, 2 changes with Pennzoil Ultra Platinum 5W30 and then the next 4 oil changes 0W40 Pennzoil Ultra Platinum. Move from 5W30 to 0W40 was due to oil shearing slightly below grade spec and wanted more viscositysafety margin.
Oil analysis for every oil change, even at last change where metal was found. Oil analysis values were good up to 13,801 miles then something went wrong and is failing in the rotating part of the engine.
My Aluminum and Iron values were as follows:
544 Miles - Aluminum 6, Iron 16
3,484 Miles - Aluminum 2, Iron 15
5,923 Miles - Aluminum 3, Iron 9
10,093 Miles - Aluminum 3, Iron 7
13,801 Miles - Aluminum 3, Iron 7
17,732 Miles - Aluminum 15, Iron 30
While Oil Analysis is a good thing, IMHO it only tells part of the overall engine health. You really need at a minimum a good magnetic oil drain plug, more for an "indicator" of Iron in the oil and it can capture and hold Iron. FilterMags are also very useful to capture and hold Iron both as a safety net for "fines" that may pass through the filter element, but also as an "indicator" of Iron build up during the OCI. An interesting benefit of the FilterMags is they can magnetize the steel oil filter housing over time so when the FilterMags are removed the Iron tends to stay attached to the inside of the oil filter housing.
What my situation confirms is the following:
1. 0W40 oil will not save a "Healthy" engine with a supposedly "GOOD" crankshaft that had been corrected for machining and surface finish error, so by the transitive property 0W40 will not save an Recalled engine with a "Bad" crankshaft that has passed the Pico test. IMHO this is not a crankshaft finish issue, it is a much bigger and complex issue. My engine supposedly had a "GOOD" crankshaft and had not had 0W20 oil since 544 miles.
2. There are engines that have not seized on the highway that have metal in them and are still running that do not make noise and will they will likely pass a Pico test. If you have an L87, you NEED a magnetic drain plug and you NEED to change your oil at least every 3500-4000 miles. Hopefully you will see a problem before you are stranded.
3. 2024, 2025 and 2026 engines outside of the original recall window are not safe from this type of bearing failure!! Mine is one of these and there are hundreds of reports of 2025 and 2025 engine failures.
4. My case almost fully negates GM's Pico test and oil substitution of the original recall, BIG PROBLEM FOR GM. While my engine has not had a Pico test at this point, based on my familiarity with how the engine has run and sounded for the past 15,000 miles, I expect that my engine in the current condition would pass the Pico test with ease. The only part of the recall that worked was engines that failed the Pico test were replaced, BUT many of these replacement engines have also failed. The early replacements were new builds from the L87 assembly line, they extended the hours of the line to meet the engine demand from the recall while they scrambled to get cores back and work with 3rd party rebuilders. So the same engines that were being installed in 2025 and possibly 2026 models were being installed in early recalled vehicles and were failing. Not a good situation.
5. This is going to be a BIG problem for GM and 1,000,000+ L87 owners.
6. Do not trust your L87, especially if you do a lot of highway driving and highway driving in rolling hills or even in relatively low mountain cuts. Towing, I would not consider it unless it is just around town.
Failure theories are many, but personally based on my situation and after much research and investigation, it seems if these L87's that are used mostly in and around town with little long distance highway use, these engines may last 25k+ miles. But if you are a highway warrior, forget about it. This problem is a general oiling system problem along with Low RPM/High Load operation with rapid Load spikes on inclines where the engine Load spikes within a few seconds from 30-40% to 90% percent. This Low RPM/High Load operation with the Load spikes is likely collapsing the oil wedge and causing Mixed Mode or Boundary Layer lubrication in rod bearings that are not polymer coated. Some of this load spiking is due to the TCM (Transmission Control Module) holding the vehicle in 10th gear and not allowing the the transmission to downshift and the engine RPM to increase for fuel economy. There will be more information forthcoming on this in the next few weeks. This is not the only failure mode of the L87, but seems to be a very common one that is impacting thousands of owners.
I am just 1 of many L87 victims and I feel for every L87 owner. NHTSA will likely force GM to Re-Recall the original 600,000+ vehicle population and add at least the last of the 2024's and include 2025, 2026 and possibly 2027 large SUV's if they still are being produced with the L87. GM may delay or stop production of the large L87 SUV's in late 2026 or early 2027 and switch over to the next generation 5.7l or 6.6l engines. Unclear what may or may not happen with the 2019-2021 models. If GM issues a recall for somewhere in the range of 1,000,000 vehicles, I expect some sort of attempted software fix like what was pushed for the 10 speed transmission lock up problem. I suspect TCM and 2 stage oil pump software changes at a minimum. But many engines may need to be replaced as well.
If any sort of Pico test will still used, very likely the Pass/Fail parameters will be radically changed and the engine condemnation rate will skyrocket. I have heard that GM and other manufacturers have started to include real time Pico type testing using existing engine knock sensors in updated ECM/ECU flashes in an attempt to notify the driver of an impending engine failure before it occurs. I was told for vehicles already sold there are new ECM/ECU flash updates to monitor the engine for noise and vibration that indicates a possible impending failure and a SES/CEL is supposed to light up and/or maybe even put the engine into a Limp or Reduced power mode and possibly display something on the driver information center. Time will tell, but it will not be pretty once the new Recall procedures and vehicle numbers are released. I am 99%+ positive there will be an updated and expanded Recall.
During the most recent oil change at 17,732 miles, the day before I was planning a 1,000 mile round tip, this is was I was greeted with when I changed my oil. Luckily I had the magnetic drain plug in the engine to see the Iron, otherwise I would have likely blindly changed the oil, not cut the filter open because I was running behind, obtained the oil sample and sent of for analysis which takes between 10-14 days for results to be sent. And even my results did not really indicate how bad the engine condition was. This may have been due to the magnets holding a lot of Iron that did not make it into the oil sample. Maybe I would have made my 1,000 mile trip without a problem and when I got my oil analysis results I would have cut the oil filter open to see what greeted me, maybe I would have been stuck on the side of the highway in the middle of nowhere. Magnetic drain plug for the win!!
On to the show!
J
jfoj
The problem here is I have no interest in a replacement L87 from GM as I have absolutely no confidence it would last. Chances are I actually extended the life of my engine buy switching to higher viscosity oil and changing so frequently. What happened between 13k and 17k miles is anybody's guess until the engine is torn down. Oil analysis did not show this storm coming. I was just stupid lucky I had a magnetic drain plug and was changing my oil at around 50% the OLM and found the pretext of an engine that will likely seize on the highway in short order.
Lot of things going on in the background.
PPK_
Oklahoma City
6.2 is a big motor... but something is giving way. i bought an SLT in Dec of '24 with a 5.3... i was afraid of 6.2s not lasting. Pico test? i have done vibration testing way back. you run the bearing.. gear sets.. all up and down the rpm range. running as GM says at 2k rpm.. has the oil pressure up.. which keeps clearance from making much noise.. i do not know why they don't at least check it at idle.. with oil pressure down a bit. what a hoax...
you are under the 60k warranty. i would run it.. i would not let it sit. or sell it. or.. get a warranty to 100k. that is what i did.. i did a 72k/72 mo one.
my 5.3 had a lot of contamination the first three oil changes. i had 2018 5.3 that was perfect. this is not really anything better than an old briggs. terrible. tooling is old.. and maybe they left out some cleaning.. in any case... probably not a GM next time. look at the path of the drain oil in the bottom of my bucket. it is terrible. terrible engine assembly. but GM knows what is needed to get to 60k.
West 1
We provided GM with Federal Mogul engine bearings for over 30 years while I worked there. I have been out of the loop since 2019 but I am really curious who is making those bearings that are failing today.
Starting around 2004 Fedeeral Mogul was supplying bearings that were high silicon aluminum on a steel back. The high silicon bearings could actually polish a rough crank surface smooth. Very cool technology.
Makes me wonder if GM was buying the high silicon bearings, reduced the crankshaft finish because the silicon bearings were not damaged by the rougher finish and then later switched to a less advanced technology bearing that is failing on the same crankshaft finish????
The high silicon bearings could be installed on a crank with maybe a RA of 30, run that engine 10,000 miles and the crank would measure an RA of 12-14. Amazing technology. The bearings polished the crank withoiut showing any wear. When introduced the only negative was the aluminum silicon bearings were limited to around 450 HP. These were using material classified as A500. I understand an A600 was introduced later that could handle more HP than the A500 while still offering the same advantages.
My information is now obsolete because the industry changes every day. As I was leaving the industry import engine bearings were starting to infiltrate what used to be a US made only business at the OEM level. No idea who is supplying the bearings or what quality they are today but bearing failures have not been an issue for 50 years so what changed?
J
jfoj
Unfortunately I really think this problem is more than just a basic bearing material 101 problem. It is hard to explain quickly and easily, not going into great detail, but here is the jest of things.
You have mentioned bearings limited to 450 HP, the problem is not with horsepower. Think of Horsepower as how FAST you hit the wall and Torque as how FAR you push the wall.
While some bearing material and coating processes could help this situation, the real problem here is Low RPM/High Torque spiking/flashing and continued operation in some Low RPM/High Torque driving conditions that is causing the collapse of the oil wedge and the oil wedge not being able to regenerate itself fast enough due to the low RPM of the bearing journal under extreme loading. This causes flashes of Mix and Boundary layer lubrication. There may even be oil volume pumping and/or cavitation of some sort occurring which would be very hard to identify.
Add to this the poor oiling path design of these engines, the oil volume and pressure hungry DFM and Variable Timing cam control along with lower viscosity oil and you have a perfect storm.
Sure things like bearing journal hardness, surface finish concentricity and bearing oil clearance all play into things, these may not be as big of a factor as the extremely lower RPM with high Torque spikes/flashes that go from 30% to 90% loading in 1-2 seconds.
Unfortunately the oil pressure gauge is located just after the oil filter at the rear top of the engine block before the oil is distributed to valvetrain, camshaft and lastly to the main and rod bearing. With the variable displacement oil pump, it continuously modulates volume and pressure which is likely leading to unstable oil pressure and volume at the far end of the oiling path, primarily the front main bearing oil galley which then feeds to the front 2 rod bearings, but could include any of the main or rod bearings as well.
I really do not think there is just a basic drop in replacement bearing solution to this problem.
Anyway these engines NEED polymer coated rod bearings, the 2nd stage oil pump needs to be remapped from RPM switching (around 3,000 RPM) to Load switching and the TCM (Transmission Control Module) needs to be remapped to allow the transmission to downshift earlier as the Load rapidly climbs to unload the engine and allow the RPM to increase to help keep the oil wedge alive or rebuild it quickly. The oil pump and TCM remapping will cause a fuel economy hit, how much, no idea. But at the end of the day none of us purchased these full size SUV's for fuel economy and I think we would all rather pay as you go for a reduction in fuel economy than in big chunks for multiple engine replacements. Even if the engines are covered by warranty, I would rather pay more for fuel than have breakdowns, be without a vehicle for weeks and have 20 hours of someone removing and installing nuts and bolts that may not be all replaced and properly torqued.
Stay tuned......
blanchard7684
Senior Member
Damn dude. Your situation is a nightmare for GM. You could not have done more to keep this engine's bearings happy.
My running hypothesis was that someone with " enthusiast" levels of maintenance will likely not have this issue. Early oil changes, disabling DFM and ASS, would get the engine to a respectable mile range. Further that there would be a separation on oil viscosity used.
Well...throw that in the trash.
There is something more complex going on. Your situation proves this so clearly it is past intelligent debate.
My first instinct looking at the failed bearings in the L87 was that it looked almost textbook in a lack of lube issue.
A low rpm and high load condition combined with a transient or intermittent "glitch" in the oil pump switching would make a ton of sense.
The L84 for sure doesn't have that load condition, ever.
I've been driving some other platforms that are on the extremes of power/liter and the highway cruising rpm stays 1800-2000 rpm and the down shifting is very aggressive towards unloading the engine.
Marky Dissod
6.2L is a big motor ... but something is giving way.
Although it is interesting that the other displacements are not suffering the same fates at the same rates, displacement has little to do with it.
'Something that is giving way' well before the engine is installed, nevermind started for the first time.
GM will never come anywhere near taking anything close to full responsibility for this calamity.
West 1
Diesel engines are making almost 2000 pounds of torque at 1600 RPM and do not have bearing failures. These are heavy duty engines, Cummins, Detroit, Volvo etc. They last 1 million miles between rebuilds.
There is a defect in the 6.2L that needs to be identified. The 5.3L runs the same RPM and transmission with no failures so far?
I just looked up normal Oil Pressure in a Cummins ISX, a very popular Class 8 truck power plant. Horsepower up to 600 and torque around 1800 ft pounds. Hot Idle oil pressure 20 psi, 2200 RPM 40 to 50 PSI. I looked it up thinking these big rigs must have 50 PSI at low RPM. These engines pull very heavy loads, 80,000 pounds at RPM of 1400 to 2200 and don’t fail engine bearings.
J
jfoj
It really has to do with the driving condition and the rapid Torque spikes. I really doubt a typical Diesel engine could match what is happening in the L87 and I would think most Diesel engines are designed to handle the abuse far better as well.
Not going to get into a drawn out discussion, but Diesel engines tend to be designed with larger bearing journals to distribute the load better, additionally Diesel engines have a more robust oiling path, not a sub standard oiling path that has been carried over for generations. Who ever thought it was a wise idea to feed the main and rod bearings last in the oiling path clearly was not paying attention.
Some of the L87 abuse is actually happening as low as 1200 RPM.
While the 5.3 may run similar RPM and the same transmission, the 5.3 behaves VERY differently for a few reasons, the primary reason is it has far less Horsepower and Torque and because of the lower available Torque the TCM (Transmission Control Module) programming is different and it will not hold top gear(s) near as long as the 6.2l and the 5.3l transmission downshifts and keeps the engine revs up and unloads the engine very quickly.
There are a lot of people looking at this situation which I have been talking about for almost 2 years.
There are multiple failure modes for the L87, however, the bottom end bearing failures are the bulk of the failures and there does not appear to be an end in sight at this point.
blanchard7684
Senior Member
Diesel engine bearings and journals are also much bigger than the l87. This reduces loading pressures.
And the oiling system in the commercial and industrial diesel engines likely aren’t a two stage system.
West 1
I have held most engine family bearing in my hands. The Cummins ISX bearings are not 4 times larger than the 6.2L bearings but they handle 4x the load.
GM has an issue with the 6.2L, they know what it is and the correction needed. At this point they are managing the damage and trying to avoid future liability while hoping more of the 6.2L engines get out of warranty.
If I find one of the failed engine 6.2L Tahoe or Yukon I would buy it and rebuild it. Properly built they will be reliable. I would want 30 PSI at idle hot oil pressure or more. I will accept the minor MPG loss due to higher oil pressure.
Good crankshaft grinders are hard to find but they are still out there. I would stick with Clevite, Federal Mogul or Mahle for bearings.
J
jfoj
Unfortunately GM does not know what the issue is with the L87 6.2l otherwise there would not be failures of post recalled late 2024, 2025 and 2026 engines and my engine would not have failed. Additionally the remanufactured L87 6.2l are failing as well. This is not as simple as just the wrong or a bad batch of bearings. There are likely many fundamental problems in play here.
The L87's have approximately 45 PSI oil pressure at idle, the 2nd stage kicks in above 3,000 RPM and I believe the pressure spikes to around 80-85 PSI as I recall. BUT this is measured after the filter before it hits any oil galley's. The question is what is the unbuffered oil pressure look like for the #1 main galley in the front of the engine, this would help answer some of the questions about all these failures.
I am pretty sure GM is using one of the bearing vendors you mentioned above.
tom3
What worries me on this one the OP is posting is the owner maintenance and the oil changes with non-spec oils. Depends on how picky the dealer is when that motor grenades maybe but I'd sure be concerned about the warranty coverage being denied.
Marky Dissod
It is not as easy as you think for a carmaker to get away with
"yes, this L87 was built wrong, not cleaned during and after assembly, and the resultant swarf killed this L87 ...
but this L87 used a motor oil that is proven by tribilogists to protect better than Dexos AND STILL FAILED,
so we will not honor the warranty on this one even though it is CLEARLY our fault"
as you think.
How easy do you think it is for a carmaker to detect a motor oil proven by tribologists to protect better than the Dexos spec?
J
jfoj
I am not worried about how I maintained the vehicle or what oil I used. I have evidence that the products I used provided more than adequate engine protection during the times I used "non spec" oil. Any and all modifications have nothing to do with the engine failing. I am being 1000% transparent and up front with GM and others. Really not worried about dealerships at this point as this has become a much larger issue. I am not really interested in the current generation of replacement L87's as they have not proven to last any longer than the originals, either directly off the assembly line as new engines and probably even less reliable as remanufactured engines coming from 3rd party rebuilders.
More to follow....
PPK_
Oklahoma City
The Pico... is a ruse for the transportation department. it will never work at 2k rpm. it might show a motor on its way out. i can see many bad engines going right on through with 40 or 50 psi of oil pressure at 2,000 rpm. Then again maybe this was to get the leaders of GM on board with this offering to the customer. Maybe they are goobers this was done to keep on moving on to next year.
Once again my 5.3 in 2018 was a great engine. Oil change a 500 miles was perfect. Nothing on the magnet after that either, all the way to 50k. But anybody with some mechanical know-how realizes how the 2024 november built has such as Briggs and Stratton look about the mess that came out with oil (see above). It is terrible.
When i got my first free change from GM i took the pictures to GMC service desk.. they just looked at it and said it if blows you get a new engine...
That is not satisfying to me.
The other GMC i have has the 3.0 liter and it is clean. New tooling? i don't know. I did run four or five changes at 500 miles each through this 2024 before it cleaned up. now it is ok.
I recommend everybody who does have some issues.. get a vibration test down. then you know. this is a terrible deal put on us by the vendor... then you know if you pull off the oil pan.. what to mic.. and check.
J
jfoj
as you think.
The L87 problems are not likely caused by machining debris as claimed or clearly not in my case based on what information I have. The L87 engine block is nothing new, pretty much identical to the L86 and many other GM aluminum V8 blocks, so what changed or what cleaning process was eliminated? A crankshaft and connecting rods offer no challenge to clean. While there may have been some machining debris, there are likely more factors at play here.
I will say I have been inside many original and subsequent L87 oil filters for 2024 and 2025 models and I am not very comfortable what I am seeing and it is not fine swarf, but it does appear some internals are beginning to have problems, but oil analysis is not picking up what I am seeing as this debris it is caught in the filter element. Machining debris should be picked up in the first few filters assuming it is not blocking an oil passage and stuck in the engine, then it should start to diminish quickly over time. Only fines that pass through the filter are likely to be found in an oil sample as they continuedly circulate through the engine and oil filter, larger heavies may fly out into the drain pan before you can get a sample container in place to catch heavies so these are likely missed during oil sampling as well.
It's super easy for a manufacturer to blame machining debris or component machining as this is a "Process" problem, not a "Design" problem. A "Design" problem or defect is way harder to get out from under than a cleanliness or machining "Process" problem, especially if you can blame it on a 3rd party vender. "Process" problems can be explained away and the window of the problem will usually be narrower than a "Design" problem that will impact the entire population. I have 5 oil samples for the each oil change that all looked very good. The lab even stated that the oil samples from the oil change prior to finding the crime scene were considered "excellent" overall for wear metals and contaminates lower that averages from the sample population the oil analysis company has reviewed. Additionally the magnetic drain plug was about expected for a low wear motor during the the prior oil change before the Chia Pet magnet was found.
More will come to the surface over time, I am no way going to be putting my family back in any L87 unless I personally build it and build it and build it my way with a few different parts and a few modifications. Even then there may be some programming things external to the engine that I cannot change that would not leave me 100% comfortable at the end of the day.
If I had it to do all over again, I might run in Tow Mode all the time and/or L8 on the highway and eat the cost of fuel. I would rather have a slightly lighter wallet than be on the side of the road stuck with family and pets wondering if I am safe distance from highway traffic and how many hours before the vehicle is picked up from the middle of nowhere, then figuring out how to get alternate transportation to get on with the rest of the trip.
J
jfoj
Agree that the Pico test is very limited and will not likely catch a problem engine like mine. My engine appears to be quiet to me at this point, sounds like it has for the last 17k miles, but this being said, the Pico test "could" be more sensitive, BUT like anything, someone derived the test procedure(s) and determined what the "Pass/Fail" threshold is.
I am pretty confident that the original recall will be expanded, a new recall number will be assigned and new procedures will be part of the recall. IF the Pico test sticks around, the "Pass/Fail" parameters will be much wider and there may even be a more rigorous service bay test or possibly even a road test procedure.
I hear you with all the trash in these engines, I have even been following the 6.6l L8T engines a bit and even that crowd is seeing trash in the engines and oil filters early on even at the first oil change. Totally unacceptable today with modern manufacturing processes and all the knowledge that over 100 years of history in the industry should provide.
I feel too much Computer Aided Design and Computer Simulation for both Performance and Durability/Reliability has been put into play here. Some form of statistical QC rather than simple things like visual inspections. Pull every 150th oil filter to cut open for inspection after the Spintron cold testing at the Engine Assembly plant and then do the same after the vehicle build and final chassis dyno testing is performed with a hot running engine that has been through some revs. Then you can see in real world terms what is being picked up in the oil filter (which should be next to nothing) and you have a very narrow build window to perform a Closed Loop correction process to make and implement changes to improve the product quality. You then know in chunks of hundreds, not thousands or millions where problems are and what they are, correct the problems early on before they are in the wild. The Japanese manufacturers are probably far better about looking at QC with a microscope as they do not want bad press to tarnish their long term reliability legacy, it does happen, but the Japanese manufacturers are really worried about their reputation more so than their bottom line. But a bad reputation does impact the bottom line at the end of the day.
LEsoftballdad
Suffolk County, NY
I'm sorry you're going through this issue. Sadly, these issues have been known for some time now, but people keep buying them. GM stock is up almost 70% over the last 12 months, so with the shareholders not complaining, the company won't do anything of consequence.
The failure rate in the latest NHTSA report indicated it could be at least 3%, but techs will say it's even higher. When the average, industry wide, is 0.5%, 3% is an enormous number. And since these engines will be in production for at least another 6-7 years, the true depth of the issues won't be known for a decade.
alexblagoev
