Misfire issues-Resolved
Normanator
2018 Yukon XL, 5.3L, 94k miles
Started running rough, pulled codes and got multiple misfire, so I replaced the coils, plugs, and wires (all with ACDelco/OE stuff), cleaned throttle body (did relearn after and installed new gasket on it), and MAF, plus new air filter for grins. Still had an issue, then started to get random other codes like BARO improbable readings, idle air temp voltage high and low, and a brake module code. Replaced MAP too (for BARO codes) since it was right there, but no change, it still throws misfire codes, but never a specific cylinder one...
At this point, I am out of ideas other than maybe a new battery (5 years old, but sits right at 12.5V after sitting for several days, and 13.9 when charging).
Any thoughts or help is appreciated!
Fless
Moderator
People's Republic of Colorado
What specific codes are you getting now?
The battery sounds like a likely suspect due to age; charge it up and have it load tested by a reputable mechanic or parts store. But just to rule it out, use a good scanner to do a crankshaft position relearn.
Welcome to the Forum from NH.
Pics of the truck, please. If we can't see it, it does not exist.
You are already receiving clarifying questions from the knowledgeable folks on this Forum.
List all of the codes that your are receiving, as they will help us to help you.
Rygrego
Topock, Arizona
Currently P0300 and P050D, misfire and rough cold idle.
I would be looking for a vacuum leak and a possible battery issue. Parts cannon is not a good way to go unless it was due to be done. 12.5 does not mean a good battery, it means a fully charged battery, there is a difference. The battery should be load tested.
N
Normanator
Vehicle is at 98k miles, so plugs were due, and it had no name coil packs on it, so it was worth switching those to known good ones. The battery is definitely suspect, and will be swapped with another we have here to test that out as no place nearby will do anything but charge it for you. Since swapping out the MAP there has been no BARO codes, so that was likely the issue with those.
As far as a vac leak, nothing else has been touched, and I have sprayed ether over ever place I can conceive a leak coming from (intake boots, manifold runners, pcv components, throttle body base, etc), and nothing reacts to it.
West 1
When you run your scan tool always hook up a battery charger or run the engine. The vehicles modules in a Key on Engine off situation give a very strong battery drain. After a few minutes key on the battery will often dip below 12 V which will set off many other low voltage recordings in many systems and some will set off a check engine light.
I suspect you have one problem to find and fix and the others were all triggered by a low voltage situation which may just be due to scanning without a charger hooked up.
My battery charger only puts out 25 amps on full charge. On some vehicles 25 amps is not enough to maintain a full charge for very long as the vehicle might be pulling 35 amps key on engine off.
My older 2008 Denali will pull maybe 18 amps Key on engine off normally but your rig is newer and the newer rigs typically draw more amps.
If your battery is marginal this all gets exaggerated faster.
It seems every time I go to scan a vehicle I think, this will only take a minute and don’t hook up the charger. Murphys law it seems 10 minutes later I am digging out the charger because I am getting low voltage warnings on my scan tool.
N
Normanator
Swapped battery for a new one and the scanner started giving a misfire cylinder 3 code instead of random misfire. Swapped coil to cylinder 1, code followed the coil, so I made the parts store swap it with another (since it was just a week old).
So far, no more codes or CEL, and she runs smooth as ever!
Great to read then. Looks like your issue has a resolution.
Please add the word either SOLVED or FIXED to your thread title, so that folks will know that this thread has a specific identified solution.
Usfiddler
Coolant censor can screw up the mix causing all types of problems, start with the cheap parts it’s $35. Lol
thatboy_eddie
