craftyorganic
- Joined
- Aug 19, 2014
- Posts
- 11
- Reaction score
- 0
I've posted here before to share my first solution. However, this is an update because I've finally found a solution that works great, has minimal cables.
I found an HDMI to Composite Converter on Amazon and it works!!! This is an option that will work with current iPhones which have a Lightning connection. First, get an Apple lightning to HDMI Adapter ($43), an HDMI to HDMI Cable ($7), and an HDMI to Composite Converter ($34) The composite Converter doesn’t need to be plugged into any power source. Plug the Lightning to HDMI Adapter into your phone, attach the HDMI to HDMI Cable, then attach the HDMI to Composite Converter. Plug the Converter into the composite (red, white, yellow) connection on your vehicle. This route will cost you around $85 but it works great with current iPads and iPhones that have the lighting connection vs the old 30-pin connection.
I posted about it in detail on my blog if you're interested. I hope this helps save someone time and frustration!
http://www.craftyorganic.com/category/reviews/2015-gmc-chevrolet-iphone-cant-watch-videos-solution/
