Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
So I installed a 4th gen Apple TV in my 16 platinum. And yes AirPlay works without having a wifi network. I'm grandfathered with unlimited data with AT&T for my iPhone and iPad so this helps with music and movie streaming.
www.ifixit.com has a teardown of the new Apple TV. When you open it up you can disconnect the 120VAC to 12VDC power supply and solder on your power connections. I also added a power switch in the center console if I ever wanted to use the rca jacks for something else.
I found a wiring diagram online for the RCA jacks in the rear of the center console. Im using an HDMI to rca converter. I cut one end of the rca wires and spliced into the factory harness for the RCAs
I did get the 10 gigs good for a year from OnStar for $100 if I wanted to but I have all the same apps on my iPhone. The other nice thing about the 4th gen ATV is you can download games to it. I'm trying to find a way to use the flash storage it has for media storage.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
