3/6 drop 2016 escalade. finally done!!
NORCAL SS
SUV SUSPENSION GURU
Im done. Very happy with ride. Removed rear autoride and with my 6" springs sits perfect.
295 30 26
32.25 front 33 5/8 rear from ground to fenderlip
I will be adding this kit to my new site eskyowners.com/store shortly
BADRIDES
What shade tint is that on the side windows?
guy from norcal
That looks killer tony!
Did you use a panhard bar or any of the spohn upper/lower rear arms ?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
not yet the rear is different on these trucks. you can fit 11.5 wide wheels in back prob 12s gm moved the arms inwards on the lowers front. The bracket sits in and unlike the 00-14s when you do 6 inches on 26s the tires touch the lower mount these still have tons of clearance.
BADRIDES
I was looking in the thread where u added the bright lights around the license plate. Are the bulbs really that bright and worth the extra money $13 a bulb.
BADRIDES
Just curious as to how bright they are gonna be as the bulbs will be coming in from the side on my 02 model where the bulbs come down from the top on yours.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
you want to set up the correct bulb for application. If its side only you want side facing led. if its top down then you wand the end facing led.
BADRIDES
these might not be the right bulb for me then
GusSanchez300
Miami FL
how come it sits level? i thought that with a 2/4 or 3/5 is to sit level. did you had to do something different, or is it because of the auto ride height that changes? Looks sick btw :worship:
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
No all 2015s sit much higher in rear. A 3/5 back will still sit up way higher. A 3/6 will bring it more level. Plus my kit is adjustable for 5 or 6.
GusSanchez300
Miami FL
but a lot because i found a deal on good tires that its to good, 544 for all 4 tire with taxes
and i cant seem to find 295s for a good price anywhere
tbordenet
Hey Tony, Is it possible to trim away all the rubbing with a 305 30R26?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
i got my 295 30 26 on ebay lexani for 550 shipped
Drewphil
