2017 ESCALADE LOWERING
aw1skate
I have a 2017 Escalade (Magna Ride and air shocks) we installed the #1019 2" Beltech drop spindle kit with 3/4" coil springs and shock relocators in the rear. Once it was done we noticed the drivers side was significantly lower especially the front. (GM lean).
26" wheels 305/30 all around.
Anything we have done ended up lifting the truck back up in the front by the time it got completely level.
REAR- We removed stock top spring isolators and used 5/8" heater hose on springs, added 1" spacer on driver side rear. Rear Level
FRONT- Added 3/8" inch spacer to bottom strut mount- FRONT WITHIN 1/4" AND DRIVER SIDE IS STILL LOW BUT LIFTING BOTH SIDES TO CORRECT
WONDERING
Anything to be concerned about in the rear? I see mixed information about cutting off brackets and some kits have sway bar links. I do have the shorter leveling sensor rods installed
Should we do 1-2" strut coil springs in the front and add spacers to get it back up to level and maintain low ride height with working range of magnaride?
1948Buickroadie
