chaingun427
OBS Mad Scientist
Mooreland, OK
Completed my bixenon projectors and assembled my grill
It's not bolted down yet, as I need to redo my bumper supports to fix a small tweak from the po
Sent from my SAMSUNG-SM-G925A using Tapatalk
Czykats44
Dis Member
Glenville, NY
Dude, that truck looks f*ckin mean!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
chaingun427
OBS Mad Scientist
Mooreland, OK
Thank you sir! I'm waiting on 2 more fittings to arrive for the cooling system and I'll get to find out if it runs as mean as it looks
A bit more reassembled today, just the battery tray, steam lines, and fan left before I can turn the key
xanatost
Lafayette, La.
Installed new tail lights and off-road tail lights guards. This coming weekend will be installing topkick door handles, new door speakers, and overhead DIC computer.
Sharpieferrari
New Lenox
10lbs of boost
Just installed a manual boost controller. Turned the boost up a bit. Going to retune and hopefully exceed my 8lbs numbers of 660ft-lbs of torque! I'll update my photo. This is from three months ago
99YukonSLT
Ohio
Picked up some 5100's and Hella 450's from summit on my lunch break. Hopefully get those mounted here soon before it gets too cold. The Hella's will be going in my diesel bumper I swapped out a few weeks back once I make a bracket for them.
Also picked up a roof basket for cheap off CL
Czykats44
Dis Member
Glenville, NY
Some new light assemblies w/ mirror amber bulbs, new bumper rub strip and new bumper filler.
bigal11419
Queens, NY
All new steering parts from outer tie rod end to outer tie rod end all Moog, new upper control arms, new front axles, new front sway bar bushings, new front sway bar links, new steering gear box, and new lower steering shaft and kyb steering damper
Sent from my SHIELD Tablet using Tapatalk
bigal11419
Queens, NY
Axles were throwing grease everywhere and the gearbox was leaking fluid like a stuck pig. Had replaced the box less than a year ago so at least that part was a warranty replacement
qukon 95
put new rear u joint straps on had vibrations u joint was not centered on yoke second time this has happened ,couldn't get my ebay drilled/slotted rotors resurface the inside
surface look like i haven't been driven it for 5 yrs LOL.NEW ceramic pads/rotors
'99_Tahoe LS 4WD - AZ
Phoenix, AZ
Installed a dual 49-state legal catalytic converter y-pipe, four new O2 sensors, and a Force II cat-back Flowmaster muffler. Also had my 4L60E tranny rebuilt from a local Chevy dealership mechanic who does side work out of his house, this included the Corvette servo upgrade, 5-gear pinon set, as well as new motor and tranny mounts. For the heck of it, I replaced the TPS and the MAF assembly. She runs and sounds even better now! I had a dream of a shiny new LS motor under the hood instead of my 17 year old L98 350 but she runs great and doesn't leak so I'll see how far I can get her to go before I replace the motor. Maybe tax refund time????? I'm also considering a rear end upgrade so I can have disk brakes in the rear. Any ideas, fellow forum mates?
noJeepshere
Bountyfull, Utahrd
10 bolt from a newer (2000 up) gm suv with disks, also get a master cylinder from a 2000 classic 1 ton dually pickup, it'll be disc/disc rather than your disc/drum master.
cent frum a smaert fone
Lyle
Replaced the inner door handle. GM wanted $90. Screw them. Paid $15 free shipping from eh'bay. I wasn't the first to replace it as their was a Robertson screw holding it.
Drewphil
