Corvette Servo?
ccapehartusarmyINF.(ret)
Gilbert AZ
The Vette Servo has nothing to do with shift points or RPMS. It is a hydraulic piston, with more surface area than the factory Tahoe servo. Thus, will have a firmer shift than the factory, with the same amount of pressure. It is actually better for your transmission as you have a more positive shift.
i wasnt pulling that outta my ass i was stating the difference in how my transmission operates after it was rebuilt with the corvette servo installed vs before with the stock servo
jough
jough
Arkansas
OK, where is a good place to get a Corvette servo for a 4L65E?
Any other easy upgrades besides this one?
jough
jough
Arkansas
Can you not just use the Tow/Haul setting if you want firmer shifts?
If you do install the Corvette servo, won't the Tow/Haul mode now be VERY firm shifting?
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Except for on the 4spds, Tow/Haul doesn't change the firmness of the shift, just the timing of the shift.
agmanw8n
