Installed Intune 87 Octane Tune. NIIIIIIICE
Cmicasa the Great XvX
First and foremost I am no tuner, but this thing has woke my vehicle up. The shifts are much more precise and it feels more like I'm driving my Vette than it does my Yukon (kidding, but U get the point). :fc5716bd: Power seems instantaneous, and shifting no longer "hunkers down." Overall Love it so far. If their advertising is correct I am now pushing about 370HP/ 400lbs of torque
I did the 87 Octane tune. This may be the dumbest of all questions.. but if I had of did the 93Octane (Diablo Tune) would I have had to empty tank and only run 93 Octane from then on?
Anyway.. I adjusted
REV LIMITER 0%
THROTTLE up 10%
SHIFT POINTS various different degrees but mostly in the 3-4K range
SPARK TIMING ADVANCE/RETARD- Left Alone
FUEL RICH/LEAN ADJUSTMENT- went up 5% RICHER
CALIBRATE SPEEDOMETER FOR GEAR RATIO- Didn't Touch
ACTIVE FUEL MANAGEMENT- First I killed it.. then figured that since it only kicks in on the highway in 6th gear it seems... to turn it back on.
SHIFT FIRMNESS- Went with FIRM
SPEED LIMITER- Removed
TORQUE MANAGEMENT ADJUSTMENT- Turned off
IDLE RPM- Didn't Touch
CALIBRATE SPEEDOMETER FOR TIRE SIZE- Didn't Touch
NickTahoe15
Florida
If you were running a 93 oct tune you should run 93 full time to prevent timing retard/knocking.
Yeah. Taking her in for an oil change in about 2K miles so I will load back to factory first and then when I bring her home I'm gonna try the 93 tune and see if its worth the extra $300 a year at the pump
amscomps
About how much was the cost on the Intune setup? $350 ish? And why would you put it back to stock for an oil change? Will it cause an issue at the dealer? Thx
I'm cautious. I don't kno what kind of testing they do when U aren't looking. When U load it... the device take a snap picture of your orignal setting and backs it up so U can restore if necessary. It doesn't leave a trace of the tune, or the fact that U did it. Sorta like doing a Restore on your PC, phone or Tablet.
Not a big deal as the parameters I adjusted I took a log so I can put it back in withing 10-15minutes. I paid $495 for the first Intune because it is for my Stingray and I'm getting a custom tune that is included in the price from DiabloLEW. The one I bought for the Yukon is not getting a custom tune and I paid $325 for it for a Black Friday deal. So for the Vette.. $170 more for Lew's expertise. Had I not wanted the custom tune I would have paid the same price for both ($325 each).
I got it here http://jwmotorsportsllc.3dcartstores.com/Diablosport-InTune-Tuner_p_20.html for $325 for the Holiday price. It is back to $389 now, but well worth it considering I enjoy driving my Yukon about 100% more than I did before. I haven't been able to test my Vette out because its been raining here. Tomorrow is supposed to be dry as a bone so I will try that one out then. I already loaded it.. Just waitin :Insane:
On going mod. TURNED OFF AFM tonight. Liking how it feels without V4 kicking in. Also upped the throttle and shift firmness by another 5%. Man this thing is fast now.
fiatdale
Houstons Best
Houston
As someone who has been a mechanic and body man at a dealership for years, trust me, no mechanic will do any test on a brand new vehicle for an oil change. It would be free work, and we just don't do that, unless asked. Oil change will likely go right to quick lube / quick service. Those guys know how to do two things. Drain oil and refill. I wouldn't worry about a thing, leave the tune in. Its not like it will be bearing the scarlet letter when you bring it in.
Thanks... I'm looking 4ward to driving her today again as the mods I made last night can be further investigated.
Side Note: Fuel economy is not as efficient when U up the power and shifts. Obviously that's the reason why GM programs them the way they do.
gemarsh
Central NE
So you have the Throttle adjusted to 15%? Does that take care of the dead spot in the gas pedal?
I ordered mine last night, and was hoping it would take care of the deadspot from idle to moving. Seems like I have to push the pedal an inch before rpm's increase.
Did it take care of the speed limiter also?
I'm sure it won't, but can you adjust anything to get second gear scratch?
humer101
NJ,USA
Yes is big deal my throttle was adjusted too 12% for better response and is unbelievable fast,no more lag. 93 octane from day one. [emoji573]
Actually even at 10% U would notice a difference. At 15% it just needs a tap of the foot. I'm almost curious what 20% would do.:party52:
and yes U can take care of the limiter. Make sure to kill Torque management
---------- Post added at 09:26 PM ---------- Previous post was at 09:24 PM ----------
But U have a Denali. 6.2L requires 91-93octane from day one. I have the 5.3L and am considering doing the 93 upjump, but kinda like the cheaper gas
humer101
NJ,USA
I do use 93 on my previous Denali too, It fly brother, and I think we better don't worry about gas prices. [emoji562] [emoji618]
^^^ I get U.. the Denali 6.2L and Escalade have always used Premium. The 5.3L uses regular. I can install the 93 Octane tune from the Intune which will actually allow the vehicle to utilize the additional octane and boost power thru adjusting the timing. Even with that I still won't be making 420HP/450lbs of torque like the 6.2L. I will be at about 380HP and 410lbs of torque, but the way I have been able to tune the throttle, adjust TM, and rework the shifts I'm betting I could run with one off the line.
humer101
NJ,USA
^^^ I get U.. the Denali 6.2L and Escalade have always used Premium. The 5.3L uses regular. I can install the 93 Octane tune from the Intune which will actually allow the vehicle to utilize the additional octane and boost power thru adjusting the timing. Even with that I still won't be making 420HP/450lbs of torque like the 6.2L. I will be at about 480HP and 410lbs of torque, but the way I have been able to tune the throttle, adjust TM, and rework the shifts I'm betting I could run with one off the line.
This guy Justin from black bear take his time and tune this truck beautiful , is a big difference. Shift is perfect now.
[emoji573]
[emoji573]
Gotcha. I'm getting LEW from Diablo to do the same to my Vette.. I felt as tho I could handle the Yukon on my own
Bootlegfab
Any issues with a tuner as far as can the dealer tell you had a chip on if, say you take it in for some kind of warranty issue and they can the computer? Obviously you would return the tune to stock before taking it in. Also, I'm in California and wonder if they can tell when you have to smog it?
humer101
NJ,USA
Yes you will return back to normal at anytime very simple. [emoji335] [emoji573]
Jproy
^^^ I will be at about 480HP and 410lbs of torque, but the way I have been able to tune the throttle, adjust TM, and rework the shifts I'm betting I could run with one off the line.
My BS meter is ******* out here. :Nonono:
How do you figure you added 125HP with just a tune? What am I missing?
CrackerJack135
