BirchyBoy
1300 miles with 3000 NY to OK truck pulled like a champ. Never broke the 160 mark, no wobble from the trailer, with the newer helper springs from a 3500 my suspension had no sag at all. Also installed my new tailgate from a suburban to fix my window matching issues
Helper springs from a 3500? Details, details! I'm hauling my 5k camper quite a bit and the back end needs a little lift. I'm torn between adding helper springs or air bags.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
regardless you must have a weight distributing hitch setup if you want it to be safe to drive.
---------- Post added at 08:30 PM ---------- Previous post was at 08:29 PM ----------
use firestone ride-rite bags. $300 or less.
---------- Post added at 08:30 PM ---------- Previous post was at 08:30 PM ----------
160 mark?
---------- Post added at 08:32 PM ---------- Previous post was at 08:30 PM ----------
is still sitting in the hospital parking lot since i am still here.
BirchyBoy
I've got an Equalizer 4pt w/d hitch with sway control. The trailer pulls as good as it can, but I'd like to get the back end up a bit more. I had purchased a full Bag setup with of board compressor and equalizing valve but returned it at the suggestion of the RV dealer.
Might get the bags again, but if springs are cheaper and as effective I might go that route.
SunlitComet
OBS Jedi-Do Good
bag are adjustable. springs are not. not sure which set you had before but the firestones are great. install the auto level kit and you can't go wrong. easy to customize how they work.
Y2KpewterZ
Threw some Nitto Terra Grapplers i picked up of craigslist. Little more agressive then the oem spec Goodyear LS-2s..
RAWVORTEC
Lburg
Cleaned and polished it. Painted grill black. I need a primed bumper offline and get it painted black also. Anyone know of someone who sells primed rear bumpers?
jerryjoe28
That Guy
cabot AR
discount body parts ( has a eBay store under that name) I didn't get my bumper from them but now that ive dealt with them I wish I had. AMAZING customer service!
chaingun427
OBS Mad Scientist
Mooreland, OK
I had a broken leaf a while back and my truck wouldn't pass inspection, so I picked up a used set of springs from a friend who was scrapping a long bed 95 3500 for 50 bucks, I took all but the main and 2nd springs from thr 3500 and bolted them under my main leaf, the final helper spring is literally twice as thick as the stock one on the tahoe. The ride isn't any rougher, but I've got no sag at all with a load on. When you do something like this it is necessary to replace the centering pin, u bolts, and shackles at the end of the springs that keep the springs from twisting about. I also recommend replacing the plastic pads that go in between each leaf on the end to curb squeaking and to keep the end of the springs from digging into each other. Ill post a pic of the springs in a minute
newbie78
I changed the rear diff fluid because i wasn't sure if the previous owner did. There was quite a bit of metal sludge on the magnet but no chunks of metal. Hopefully i delayed the need for a rebuild or new rear for at least 3+ years.
I also tried to remove the 2 broken exhaust studs that i broke trying to change the exhaust donuts. I got new nuts and threaded them on the studs and used JB Weld on them. Hopefully on Sunday I will be able to get the studs out. I sprayed PB blast on them the other night and I will again tomorrow night. I'm letting the JB Weld cure for almost 2 days. I think it should work wish me luck!
newbie78
So you used jb weld to lock the nuts in place? Wouldn't the pb blaster keep that from sticking to the metal?
Yep I JB welded the nuts onto the studs. I put some on the threads and on top of the nut. I only sprayed PB on the top of the exhaust flange where the stud screws into it none gets down on the stud.
domer94
northwest NJ
replaced rotors and pads on the 99. got a set of "wearever" autozone brand oem replacement online all in for $71 bucks. they feel nice so far. god i love the simplicity and value of parts for these trucks! i rember having to drop $110 for each rotor on my volvo wagon.
96Taho
youngstown,ohio
Switching Stock Grey Interior Too Black Delivered My Tahoe To The Apholsterer To Have My Entire Interior Done In Black Ulra Leather And Grey Ostritch Highlights....Dying Dash And All Hard Parts Black .. Also New Chrome Interior Door Handles When Interior Is Done Im Going To Install A Few More Chrome Accents.... New kenwood Double Din Navigation-blue tooth head unit..the Kenwood Dnn9900HD... A Small Sub And New Speakers... No Boom Box... I'm Old School Classic Rock Guy... Don't Need A Thumper... All New Dash Face-Guage Needles..... Alot Of Work-Time-Money.. Somewhat Burned Out... Been Working On This Thing Almost 3 years... burned outanxious to enjoy the damn thing.. probably got at least 30K in this thing And Still Spending More....Completely Rebuilding And Changing Original Color..All New Mechanical...Think Long And Hard...!! Shit Dominoed From One Part To The Next And if I Did It Again I Would Get A Solid Frame And Body And A Stock Color I Like So I Don't Have To Repaint Door Jambs And Under Hood And Engine Bay....Definitely Learned Alot.... Mainly You Better Have Deep Pockets For A Frame Off Resto Mod
newbie78
So my JB Weld idea didn't work the nuts just twisted off like nothing. So I just cut 2 studs flush with the flange and tried to drill them out but I couldnt get a drill in straight. So i ended up putting it back together with one stud that wasn't broken and I put a 3 inch c clamp on it. Rednecked yep but that clamp aint coming off and it's not leaking.:)
Gzes
the drifting 2dr
Wichita tx
Puzzled... When I Dd the 2dr is fine but when I tow it starts to get hot... Put new thermostat but still acting up.. Might do water pump but I used to be able to go to the moon hauling cars fine
HortonHiresAHoe
Mt. Juliet, TN
I feel for you man, dying the dash was a job!! Judging by the rest of your truck, I'd guess that you're as **** as I am. I had no idea the amount of time that it would take... from tearing the vents down into individual pieces to the glove box latch, I had about 10 hrs in the dash alone. I'd say that fighting with the little springs in the 12v outlet covers was probably the toughest part. Btw, I hope this is not a dd. I only have around 300 miles on the clock since I color swapped and I've had to touch up the door panels 3 times... the dye just won't stick to the doors, no matter how much prep you do. Good luck!!!
Gzes
the drifting 2dr
Wichita tx
Gonna do that next. Might get a new one tomorrow but kinda leaning on a Efan conversion...
Escalade2007
