Buttons Suburban Build
Big Buttons
Big Buttons
The SS Burb
South Texas
Hey Buttons, how are those subs holding being vertical? Im about to build a box for my two AudoQue's and was debating on how I wanted them firing. Was told the vertical takes a toll on them, but not too sure about the source on that on.
They are holding fine. I have them out now and some 12" Type R's in for less weight. but the Fosgates were fine when I took them out.
OHSIXX
Milwaukee
Cam sounds really good....got a great chop. Your truck sounds mean as hell!!
Big Buttons
Big Buttons
The SS Burb
South Texas
Thanks man!!
---------- Post added at 09:18 PM ---------- Previous post was at 09:17 PM ----------
I tinted my tail lights today with Smoke from Plastidip. Since it is plastidip I can peel off whenever.
The cartel won't let him buy wiper blades :shrug:
M Hankel
Vancouver, WA
I can tell you right now that if you buy a a fan harness, do not get the one wire setup. Get the two wire setup so both fans are controlled by the pcm. I just got the one wire setup where the high speed is tied into the ac clutch. Such a messed up way to do it.
Mike
Big Buttons
Big Buttons
The SS Burb
South Texas
It came with a harness that looks really good. It will be hooked up to the computer and an external temp probe instead of the a/c hook up.
Big Buttons
Big Buttons
The SS Burb
South Texas
Update:
Got the e-fans in and are working flawlessly. Been chatting with Ezdaar a lot on what other mods to do and we have come up with a whole bunch of awesomeness.
The plans now are to do the NNBS 6.0 top end with my NBS 5.3 bottom end. I am almost completed with collecting parts for the intake manifold swap/injectors. Then I will for sure need a transmission, so I will be swapping in a built 4L80. Capable of handling 1500hp (no I will never be anywhere near that, but because of the weight they recommended that one).
After that I will get a set of ported and polished/milled down 799/243 heads off of the NNBS trucks. Might also get bigger valves cut. I will also be getting a more aggressive cam to match the new intake manifold and heads.
Then the last stage will be boost. I will be going with a turbo from On3 performance.
The manifold swap should be about 30whp after tune. Heads/cam should be another 50+whp. So n/a I should be around the 450-500hp at the wheels.
This will be a pretty long process since these "stages" are pretty expensive.
Now for manifold/TB ****:
tgui
^^^ Nice parts!
Its good to see another 4l80e swapper. We'll have to compare notes, especially since we have the exact same year trucks.
Big Buttons
Big Buttons
The SS Burb
South Texas
So the TBSS manifold is a direct swap onto a 5.3?
Yes, tons of people have done this swap. It is probably the most popular manifold swap out there. Only thing that was hard to do was find a cable driven throttle body since I am not drive by wire.
TxDrewski
Potomac,MT
Coming along nice Buttons!
My LQ9 should be here Friday, if you need any stock 5.3 parts hit me up. Ill be pulling the whole drive line out.
---------- Post added at 04:11 AM ---------- Previous post was at 04:08 AM ----------
Like if you needed something to practice on/work on while your engines in the truck..
You know what I mean lol
Drewphil
