Tricky
Illinois
SunlitComet, you should change both oil cooler lines to be on the safe side while you are under there. I got both of mine from amazon 2 or 3 years ago for $80.
Sent from a Phone Booth using Tapatalk
SunlitComet
OBS Jedi-Do Good
unknown at this time.
well the lower just arrived and the upper house brand one seems to still be good. got to call rock auto because I expected to have the o-rings in a bag with the oil line. instead the line came by itself with packing or o-rings but with just a delco label. all other lines i have bought have had seals and packaging. since rotors are here now I think a will stop at a shop to have the brakes done. don't have the floor jack and stands at the hotel with me.
95escahoe
Had the new shocks put on, got an alignment and had the driverside door latch replaced
Sent from my HTC One X using Tapatalk
SunlitComet
OBS Jedi-Do Good
cracked rotors and pads replaced along with one caliper. using cryo rotors this time.
---------- Post added at 07:23 PM ---------- Previous post was at 07:19 PM ----------
oh and it initially appears my power steering pump is leaking again after 2 years. I am thinking there is something amiss with its mounting system. replaced the oem 2 years after i did the head work where the mountings had to come off.
96redsport
Altoona, Pa.
Installed a new brake booster and NBS master cylinder...... Next step is to put on the drilled and slotted rotors, ceramic pads, new calipers and SS braided brake lines....
BirchyBoy
5,200 miles into our camping trip. Last leg home tomorrow and the trip will be over. The Yukon has been awesome.
SunlitComet
OBS Jedi-Do Good
new front brake rebuild completed on saturday. below is what remained of the last package but also shown were another set of sd pads that went on again this time. I forgot to get pics of new rotors but only change was the new ones were cryo'ed. let see how well they hold up to my habits. i ran these ones down to the ground while trying to get the new rotors. they had some judder issues and i was going to resurface them when i found the cracks.
http://s1222.photobucket.com/user/S...evy Tahoe 4X4/Brakes/Front brake job 06-14-14
---------- Post added at 09:57 PM ---------- Previous post was at 09:41 PM ----------
Also finally remembered to clean my k&n air intake filter. not touched since install back in 2010. i am going thru several clean and rinse cycles. here are some pics and vid of it doing the nasty in the shower here at the hotel.
http://s1222.photobucket.com/user/Sunlitcomet/library/1996 Chevy Tahoe 4X4/Intake
BirchyBoy
I'm considering putting it up for sale. It's a great rig, but I think I want to move to a newer model with the 5.3 or even a truck with a 6.0 for better towing. Not sure yet; I change my mind quite a bit.
95escahoe
Dropped it off at the shop last night to get the driverside door pins and bushings done, could have done it myself but for $90 can't go wrong
BirchyBoy
That's a great price. My shop quoted $250ish so I did it. Not bad, but not a 1 person job unless you have a way to support the door easily/safely.
noJeepshere
Bountyfull, Utahrd
Really? Wow that's a lot. My local body shop did the drivers door for $20 in 15 minutes. I had the parts already ($5 or so) and tried doing it myself when I quickly realized its not a 1 person job, even with a floor jack.
cent frum a smaert fone
95escahoe
Damn that's a ripoff, I was gonna do it saw a YouTube video looked pretty easy but for $90 said f*ck it lol good thing I did cause the bushing holes were a lil f*cked up so they had to drill them out took them an hr and a half but only charged for the hr
---------- Post added at 05:53 PM ---------- Previous post was at 05:53 PM ----------
And ya its deff pretty easy saw a YouTube video but deff need the second person
Y2KpewterZ
Hand waxed in this 110* weather. Also had the exhaust fixed. Blew the plug out of the extra o2 bung. Thought i blew a cat out lol. Had it fixed. No more rattle (thought the honeycomb was rattling inside the pipe) but all is well now.
95escahoe
That Tahoe looks amazing
Tricky
Illinois
Monstar, don't get upset, but look what else I had done,
wwiizz
