Any interest in 4wd front coilovers to replace tbars?
Tahoewhat
Ballin' on a Budget
TX
While I have the mad scientist attention haha, I stumbled across these on the old interweb,
Find this as well
So, this is where everyone has been. My thread died. ha ha..
But this pic is exactly what i have started to look for. If i remember right that would give me back 1.5" of drop i could i have. Not that i could, but a little lower would be cool or at least the ability.
For that top mount of the t-bar type, I'll stick w/ my upper b/c if you want all you have to do is bolt the shock to the original mount for the upper.
Do pm or text where you found that image of the split bottom qa1.
Atomic
Atomic
Huntsville, AL
Those shocks are from the C5 pro system, they are about $400 each, and are about 1.5" higher than using a normal mount and my bottom brackets. http://www.qa1.net/qa1_motorsports/...vette-coil-over-shocks/double-adjustable.html
You may could try and special order some shocks from QA1 with their "special" lower mount, which is what they call that, but I have no idea what that would cost or if they would even do it.
If you are willing to fab stuff yourself, then you have a world of options. I originally made my parts as something that can be easily installed without cutting or welding anything (talking about the lowers). Can other mount types work, sure, but they are a lot more work on your end.
Tahoewhat
Ballin' on a Budget
TX
I saw that price and said never mind & clicked the X. lol.
What is that end called on the stock shocks? I.E. Stud mount/t-bar/bearing end etc.
Atomic
Atomic
Huntsville, AL
Not sure...I personally call it a clevis mount but dont know what the official name is and havent been able to find it.
Bomba02
No I'm good with those shocks from the vette was just showing I stumbled across them. I was always planning on running your lower brackets. I was just thinking the t-bar could be a replacement for the stud mount upper because at the moment the stud mount top is questionable. I understand it is a bolt on and keeps everything lined up good and your brackets are awesome. Trust me I'm going to go with the same set you guys have. Well maybe minus top bracket if 04blackout reviews are good. Just need the money now.
:hmmm2:
digitalfiend
Expert Overthinker
San Antonio, TX
Hey guys just made 7 or so more complete sets last week so I have plenty to sell!
My plans changed slightly...I'll be needing only one set of the lower mounts. Do you have enough buyers to give us the sales price that you had talked about recently?
I was planning on reinforcing the uppers with your kit. After seeing 04blackout do his conversion with no issues and also talking with ridetech I'm comfortable with doing the uppers without any reinforcement.
My original plan on the lowers was to use some used djm lower control arms to get a 3" drop and just reinforce them. I got to looking at this closely and realized that the djm lower control arms get their 3" of lowering by reindexing the torsion bars...so my plan to use them doesn't do me any good.
Atomic
Atomic
Huntsville, AL
Not yet I think I have just had those 2 guys so far. With you would be 3 I guess, find 2 more and there ya go!
digitalfiend
Expert Overthinker
San Antonio, TX
Lower Mount Dimensions
I'm trying to measure for the proper shock height (extended/compressed/ride height). How much does using *only* your lower shock mount reduce the shock height by?
M Hankel
Vancouver, WA
Be careful when looking at the longer shocks. I could not find a spring manufacturer that made a 2.5" diameter, 1200-1300 lb spring in the longer lengths (7"+ lengths). Maybe I wasn't looking hard enough though. ?
Mike
Atomic
Atomic
Huntsville, AL
The required stiffness depends on shock travel. The 1200-1300 number is only for the short travel shocks.
saif najd
OK, listen!
If I want to get 1.5 up to 2inch form my front suspension (as lifting)
By mixing or using your parts AND forgetting about the Tbar system!
Can you do that? And I can get the best ride quality?
At least as good as factory ride quality and it can take side wakes jumps and dune fights
If you can offer me something good and reliable 100% for my 98 2dr Tahoe then you are smarter than "GM turtles" and I well buy it!
Sent from my GT-I9505G using Tapatalk
Atomic
Atomic
Huntsville, AL
The amount of lift you can get is the same as with a huge crank on the tbars, so 2-3" max. Any problems associated with a big tbar lift like crappy balljoint angles and bumpsteer will still be there because the truck is still lifted, this just changes how its lifted. The ride will be drastically better than with a tbar lift.
Im not a sand guy so im not familiar with wake jumps and dune fights, but I can asure you my parts wont break, or let me say, if my parts do break then what you did to cause them to break would destroy the truck no matter what lol
I am fairly certain the LCA on your truck is the same as the 1999+ gm trucks, so my lower bracket should fit fine. I am not sure about the upper shock pocket, but my brackets can we welded to the frame and even reuse the factory shock if you want to put it back to stock.
If that sounds like something you want to do shoot me a PM.
---------- Post added at 03:02 PM ---------- Previous post was at 02:45 PM ----------
So guys on the group buy:
1. digitalfiend
2. bomba02
3.
4.
5.
Is this right?
Tahoewhat
Ballin' on a Budget
TX
Come on everyone, get on the group buy.
Trust me it is well worth it. The ride will be much better. Im slammed and the ride is great for a slammed tahoe. Just see my threads, or pm me. Will help you out with any questions you may have.
500 plus miles on mine and not one issue and still all looks 100% like it was when installed.
Lifted or lowered or even stock get his brackets NOW!!!! ha ha..
digitalfiend
Expert Overthinker
San Antonio, TX
1" of shock travel == 2.25" of tire sidewal travel
I put the front of my Tahoe on jack stands tonight. I measured the location of the outside of the rim/sidewall and the length of the shock. I then cycled the lower control arms so that the shock compressed by 1" and measured the amount of movement of the outside of the rim...it moved 2.25". With my rim setup 1" of shock movement equals 2.25" of movement at the outside rim/sidewall.
DisClaimer: Bear in mind that I'm not running a stock rim...I'm running an 18" version of Enkei's RT6 that was originally intended for a Toyota Tacoma. Because of this my backspacing is slightly different than the rims that many of you are running.
A safe guideline: It is probably extremely safe to assume a general 1:2 ratio of shock to outside rim/sidewall movement...so 1" of shock movement is roughly 2" of movement at the outside of your rim/sidewall
Bomba02
1. digitalfiend
2. bomba02
3.
4.
5.
Is this right?
Yes, thinking just the lower brackets. Seems to have some good input on shock mount holding...I hope...undecided on stud mount or loop adapter for top.
Are you going lowers only? If so what top mount are you going to run? Feelings and thoughts
Billy
johnsonwillie199
