04whitetahoe
TYF PLUS!(tm)
Thanks for chiming in - Been researching this quite a bit
Thanks you two for chiming in.
I've been reading MUCH conflicting information on sub boxes/ sealed, ported, band pass, 4th order band pass on many sites and threads like Steve Mead Designs, Crutchfield, Diymobile Audio - anything that will come up in many different iterations of Google searches I've done.
It's fairly easy to say "in the right enclosure it will be great", but no one is willing to say what pre-fab enclosure is "best" or even "here's some options. I'm not having a custom box made and not building my own, so looking for a pre fab that will meet the specs of the speaker according to the manufacturer.
I appears that "Ground Shaker" has the pre fab enclosure, whether it be sealed, ported, vented or band pass that will work with my Sub.
http://www.sonicelectronix.com/item_62693_Ground-Shaker-SQPXL-1-12.html
http://www.sonicelectronix.com/item_62500_Ground-Shaker-GSP-1-12.html
http://www.sonicelectronix.com/item_62683_Ground-Shaker-SQP-1-12.html
http://www.sonicelectronix.com/item_62630_Ground-Shaker-PBP-1-12.html
Anyone have any prefab enclosure recommendations for my 12" Sundown audio pushed by a RF 750?
For a sealed application, my speaker wants 1 cu ft, for a ported, it wants 2.0 cu ft. If I can't find a box to meet that spec, should I go bigger or smaller. When I look at prefab boxes, they don't match my speaker spec.
My speaker spec says it works favorably with 4th order bandpass enclosures, thinking about the Ground Shaker bandpass enclosure from above. (Ground Shaker PBP 1 12 )
What is 4th order? Are all band pass 4th order?
Comments?
I really appreciate the conversation because I'll never profess to know it all about any subject!! In this case Sub woofer boxes.
As far as the ported for rap, sealed for rock debate. It really comes down the the subwoofer, that sundown should be a great sub.
The sealed for rock, ported for rap myth is just that.
Comments?
